07. Intermediate - 3D Design and Management
The 3D View
The Composite Model
Dynamic Properties
Combine Modes
Note:
Add
Subtract
Merge
Low
Level Mirror Modes
- Left to Right
- Right to Left
- Top to Bottom
- Bottom to Top
- Top Left Quadrant
- Top Right Quadrant
- Bottom Left Quadrant
- Bottom Right Quadrant
Multi Sided View
