Slice Model
![](https://cdn.sanity.io/images/i7cqi3ri/12/34ec684f07c97a7a489fa4765a0db03ee1851902-238x805.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/a653ad938babe73f217048a30f17b603b9ef46c5-350x238.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/8b8be9cd9c07854ab201532ca8825193e0e316f8-310x238.png)
Model Slicing
Slice Thickness
Number of Slices
Example
Create Boundary Vectors
Slice Model
Slice Heights
There are two parts to the slice height control:
- The height bar which gives a visual indication of the slice heights
- The slice list which lists the slice heights using their z value
Controlling Slice Thickness
A specific slice height can be controlled by selecting it from the slice list, updating the value and clicking
Add New Slices
- Entering a specifc z height for the slice and selecting apply; or
- Double clicking on the height bar at a particular location
![test](https://cdn.sanity.io/images/i7cqi3ri/12/519b88271ed5c5a5198732ca41a8abe0b7e015b1-214x245.png)
Removing Slices
3D View
- Red areas show which are included in this slice
- Green areas indicate that the component is above the slice height and so these will be sliced flat.
- The slice will occur between the Red and the green areas.
![test](https://cdn.sanity.io/images/i7cqi3ri/12/d56442974e186e419ab5efb9ac939a865dec46a2-1530x1150.png)
- Double clicking on the model will change the value of the active slice height to be equal to the clicked height.
- Shift + Double Click will insert a new slice height at the clicked height.
- Shift + Mousewheel up/down will raise/lower the actice slice height by a small amount allowing you to tweak the thickness to remove thin slices.
