Release Notes : 12.0
12.014
    Fixed crash when switching between full 3d and flat modes during 3d model import into a rotary job.
    Fixed crash when triangulating a 3d model
    Added GrblHAL support to VTransfer
    Fixed crash when importing a dxf which contains errors.
    Removed references to the drawing tab
    Fixed colours in tree view during 3d import segmenting.
    Fixed horizontal text in a box stretching options.
    Fixed issues when switching fonts for text on a curve.
    Fixed issue when nesting parts with multiple levels of grouping.
    Fixed visibility of merged toolpaths after recalculation.
    Fixed laser picture toolpath error when using an image with a transparent background and overscan.
    Fixed an issue that could occasionally cause an invalid fillet to be created when a very large radius was used.
    Fixed a scaling issue when opening SVG files that use centimeters as the units.
    Fixed potential crash from the tool database when dragging items when there are outstanding unsaved changes.
    Prevent some cases of zero length span creation when node editing.
    Fixed a potential issue where passes could be machined out of order when merging certain toolpath strategies.
12.013
    Fix issue with tool deletion in multi-tool toolpaths
12.012
    Fix crash when double-clicking in the component tree
    Fix crash when importing a model into rotary job
    Fix crash when setting level clipping from the level dropdown
    Fix crash when using level dropdown with the Smoothing form open
    Fix crash when creating model preview with extreme aspect ratios
    Fix crash caused by deleting toolpath while simulation is running
    Fix slowdown in 2D view when very long lines are drawn
    Fix zoom tool shortcut not working in the 2D View
    Fix issue with Job Setup Sheet overlaid text
    Fix issue with document variables erroneously marked as in use
    Fix issue with importing binary STLs
    Fix issue with job dimensions not refreshed on the design panel when changing sheets
    Fix issue with blank fields appearing when editing Sketch Carving toolpath
    Fix error message for direct output via the printer driver
    Fix issue with vector join buttons not working while in toolpath preview
    Fix issue with baking a grouped component with combine mode set to subtract
    Fix issue with Laser Picture toolpath not working with monochromatic images with transparency
    Fix issue with spikes to safe z on projected toolpaths on rotary jobs
    Fix issue with 'add side to toolpath name' option not persisting
    Fix issue with coincident lines with a different direction falsely detected as duplicate
    Fix issue with preview image in 3D being rotated twice when tracing bitmaps
    Fix issue with gauge when using tiling when plunge (Z2) gap is set to 0
    Fix issue with threading toolpath when using multi-toothed tool
    Fix issue in Material Setup for double-sided jobs
12.010
    Fixed crash when installing machine configuration ends in error
    Fixed crash when selecting sheets dropdown after document closed
    Fixed crash when using a font with missing glyphs
    Fixed crash when closing drawing form while zoom to box tool is active
    Fixed issue with Sculpting tool stuck open
    Fixed issue with Keep-Out Zones warnings not displayed correctly for array copy toolpaths
    Fixed issue with on screen help not displaying text for Japanese and Korean languages
    Fixed slow component box selection
    Fixed incorrect rotation displayed for mirrored objects
    Disable adding tabs when sharp cornering option is used in Profile Toolpath
12.009
    Fixed crash when dragging unselected component in the component list
    Fixed crash when calculating moulding toolpath with dimensioning form open
    Fixed crash when incorrect formula is entered. Also fixed issue preventing the user from correcting the formula
    Fixed issue with the rotation pivot point not updating when multiple objects selected
    Fixed a very noticeable slowdown caused by snapping when view is zoomed out with a lot of vectors
    Fixed issue with tool's projection plane not updated when modelling plane is at -1
    Fixed character encoding issue on multiple forms
    Fixed issue preventing the user from editing a moulding toolpath template when the associated vectors are not present
    Fixed issue with double clicking 3D view edit field not selecting text
    Updated support link in the startup panel
12.008
    Fixed an occasional crash when closing forms
    Fixed crash when repeatedly undoing/redoing create shape component edits
    Fixed crash in replace below tool
    Prevent crash and handle instances of missing dlls more gracefully
    Fixed significant slowdown in the 2D view when drawing thicker lines and DPI scaling is enabled.
    This primarily affected Photo V-Carve toolpath with 2D previews enabled and vector data with many nodes.
    Fixed issue with model appearing all black when sculpting with visible model option
    Fixed issue with zooming when vectors are extending way beyond the material bounds
    Fixed issue with edits to dimensions not being reflected in the 3D view
    Fixed error when 2 point polyline is created in draw curve mode
    Fixed issue with tip radiused tools not preserving carving tool wall angle in V-Carve and VCarve Inlay toolpaths
    Fixed issue with status bar surface normal display getting stuck when SHIFT+ALTreleased
    Fixed issue with direct output not finding ShopBot's control software
    Updated offline documentation
12.007
    Curve mode drawing added to polyline
    - Note: This can be accessed from within the polyline tool by either pressing 'S' on the keyboard to switch between the current mode and 'curve drawing' mode, or by clicking on the current end point of a polyline.
    Support arc drawing in the 3d view
    Allow oversized PDF files to be saved by optionally scaling to fit within limits
    Fixed 2d rotation centre bug
    Fixed text kerning cursor not always updating
    Fixed undo issue with 2d polyline drawing
    Restore ability to node edit during sweep tools
    Allow node editing to be used from within a wider range of existing tools
    Fix issue with using formulas in sketch carving
    Various crash fixes
    Improved various DPI issues
    Fixed issue allowing selection of invisible objects
    Fixed boundary tracing for thin areas
    Fix incorrect cursor showing for corners during 2d rectangle drawing
    Fix 2d toolpath previews vanishing during array copy toolpath calculation
    Fix name field not updating for Sketch Carving toolpath
    Correctly disabled paste option if there is nothing available to be pasted
    Fixed issue where rejoining a trimmed segment could sometime leave a small gap
12.006
    Fix crash when a message box is displayed
    Fix crashes with non-ascii Program Files, component selection, freehand drawing and shape creation
    Fixes to behaviour of group / ungroup button
    Fix copy-paste maintaining layer
    Fix setup sheet error
    Fix 3D zoom behaviour 'Z' shortcut
    Fix DPI glitches with the collapsed tabs
    Fix 3D Finishing toolpath remember last used tool(s)
12.005
    Add missing vertical fonts
    Fix 3D view right-click menu translation
    Fix for various DPI-related issues
    Fix issue with rotary relief displayed at low resolution after using zoom to hand drawn box or using the View Control
    Fix issue with Sketch Carving not working on monochromatic images with transparency
    Fix intermittent issue editing 2D shapes in forms
    Fixing various crashes
12.004
    Fix Vector Unwrapper tool staying active after the form was closed
    Fix incorrect toolpath output on toolchange when using different units
12.003
    Please refer to the What's New page.
