Laser Cut And Fill
The Laser Module is available as a paid-for add-on to the software. The features are not included in your software by default. To find out more about the Laser Module, please go to https://vectric.com/laser-module
Tool Selection
Select Tool
This button opens your database of previously stored laser settings for different jobs and materials. When a setting is selected from the database it will be used to populate the key fields in this section. You can subsequenlty modify these values when calculating the laser toolpath. Modifying the settings on this form will not alter the original stored settings within your database.
Power
Move Speed
Cut Depth
When you need to perform multiple passes with the laser, stepping the tool down for each pass to maintain the laser focus you can set a Cut Depth for the laser.
This will use the Lasers given Pass Depth value to determain the number of passes needed.
No. Passes
The machine can repeat a tool path several times to cut through thicker material. This value is determained by the Cut Depth value divided by the Laser's Pass Depth value. This is automatically generated and not editable.
No. Repeats
Increacing the number of repeats will increase the number of times the same toolpath is run. This option is used if your laser cannot achieve a full burn and you wish to double or triple up the toolpath to give a more intense burn effect.
Overscan
Overscan allows the user to have the laser pass beyond the edge of the lasered area, to account for deceleration of the machine which would otherwise result in a darker edge to the laser burn. This will turn the laser off at the edge of the toolpath but allow the machine to continue moving beyond the edge.
Overscan is machine dependant and the user will need to run some test images to identify how much overscan to use on their machine at a given feedrate to eliminate overburn at the edges of the lasered area.
Strategy
Based on the selected vector shapes in your drawing, this toolpath offers four distinct strategies.
Cut Outside / Right
Cut Inside / Left
Cut On
This option will run the center of the laser beam along the selected vector. No offsetting or kerf compensation is required.
Hatch Fill
Allowance
Stepover
Hatch Angle
Fill Together / Fill Regionally
These options will change how areas separated by spaces are treated. In the example of the word "Test" with Fill Together selected the letters will be treated as one whole space to be filled whereas with Fill Regionally each letter will be treated separately as its own individual region.
Cross Hatch
Checking this option will create a cross hatch fill instead of a single set of lines.
Outline
Selecting this option will then create a defined outline around a chose vector. If unchecked there may be gaps around the edges if the stepover is large enough whereas when checked an outline passing around the outside will appear.
Note:
Immediate Output
Post Processor
Add side to toolpath name
Output direct to machine
