Quick Start Guides
01. Interface Overview
- The Main Menu Bar (the Drop Down Menus) along the top of the screen (File, Edit, Model, Machine, Toolpaths, View, Gadgets, Help) provides access to most of the commands available in the software, grouped by function. Click on any of the choices to show a Drop-Down list of the available commands.
- The 3D View is where the composite model, toolpaths and the toolpath preview are displayed, and can also be used to create your Vectors, 3D models and edit them both.
- Quick Drop down menus can be accessed here to change the current Layer, Sheet or Component Level you are working on.
Managing the Interface
Accessing Auto-hidden tabs
The auto-hide behaviour of each tools page can be controlled using the push-pin icons at the top right of the title area of each page.
Cut2D Desktop has two default tool page layouts that are designed to assist the usual workflow of design, followed by toolpath creation.
Help ?
In all forms is a ? Icon which will take you to the appropriate Help Contents page to cover the tool form you are on in detail.
3D View Help Prompts
The Help Prompts will track your current tool or action and offer quick access to relevant Help documentation or tips on the current tool.
02. Getting Started - Introduction
Getting Started
Welcome to the vibrant Vectric community! You've made a great choice for getting the most from your CNC machine by using Vectric software. This short guide should help you to get your CNC machine cutting correctly in less than hour. Along the way we will highlight key concepts and tools in our full Reference Manual. These links will help you review each step in more detail and begin to develop your skills.
Overview
In the first section of this guide we will describe the main principles of CNC toolpath creation using Vectric software. All CNC projects follow a similar workflow and our software is designed to reflect these steps naturally and intuitively.
Next we will complete your one-time setup to licence your product and give you access to Vectric's online portal, V&Co, which we will use to automatically configure the software for your specific CNC machine.
In the final section we will run through a simple, but complete, CNC project from start to finish step-by-step. At the end of the project you should be confident that your CNC machine is correctly configured and you can cut vector drawings using a simple profile toolpath strategy.
03. Getting Started - The CNC Workflow
The Vectric Workflow
The Example Project will step you through all the stages of creating, toolpathing and cutting a simple line drawing. Most CNC projects share many common concepts and steps so before we complete our practical project, let's run through them.
The structure of a Vectric Job
All the information needed to describe a single CNC project is contained in a Vectric Job document (when saved they have the file suffixes *.crv or *.crv3d). A new job always begins by defining the area of a sheet of physical material that you intend to cut with your CNC machine.
Most jobs typically only involve one sheet of material, but more complicated projects may comprise multiple materials. Don't worry, your job's primary material sheet can be updated or new sheets of material added to your job later, as your design develops.
The drawings & images used to work on a material sheet can be created on layers to help manage more complicated designs. Similarly 3D model components can also be organised onto levels. By default there is always at least one layer and one level for each sheet in a new job. You can add more layers and levels to help organise more complicated projects.
Once your material sheet has been created in the Job Setup form, the software will show you a 2D & 3D view of your design space (which matches the dimensions of your current material sheet), each in their own window.
Above the view windows is the main toolbar which allows you to navigate through the structure of your CNC job and see what is currently being displayed in view windows below. It shows you the material sheet, design layer and 3D model level that you are currently working on (referred to as 'active').
What you see in the 2D & 3D design views below will reflect these current settings and any new shapes, components or toolpaths will be created in the active locations indicated. You can also change the active sheet, active layer or active level at any time directly from these controls.
More advanced projects can also represent both sides of a sheet of material. For a two-sided project an additional control above the views shows which side of the sheet is currently active. You can view the drawings, models and toolpaths associated with the top and bottom surface of each material sheet and swap the active side of the sheet in a consistent way to the other controls.
Initially your job will be empty and so your views will be blank, but in due course, Vectric's view windows will show all the layered drawings & images, 3D model components & toolpaths for the currently active material sheet.
The currently active locations are the same for both the 2D & 3D views i.e. creating a vector shape will place it on the same active sheet and active layer regardless of whether the 2D or 3D view is used.
You can, however, toggle the visibility of object types in each view independently using the visible items toolbar at the top of each view. This is helpful for focusing on different areas of your job at each stage of creating your CNC project.
Many of the software's tools can be used directly in either the 2D or 3D view.
In V12 some tools have not yet been extended to allow full interaction in the 3D - this is an ongoing transition. If in doubt, try click
Import, Draw or Trace artwork
Computer images are most often represented as a grid of coloured squares - these images are referred to as bitmaps and their constituent coloured squares are called pixels. Except for a few very specific cases, this representation is not *directly* useful for toolpath creation. Computer drawings (from CAD or illustration applications) are very different and are instead built from mathematically defined lines & curves.
This type of representation is referred to as vector or contour artwork. Vectric software can use both bitmap and vector artwork, but most types of toolpath can only be created from vector drawings. Suitable bitmaps with bold regions of similar colour (for example logos, cartoons, icons or signs) can, however, be used to create vectors from which many types of toolpath can then be generated - this process is called bitmap tracing.
Some external artwork file types contain only bitmaps (e.g. BMP, PNG, JPG), some contain only vectors but many can contain both (e.g. PDF, SVG, DWG/DXF).
Use the design artwork to create toolpaths
We use the vector artwork to define the shapes we want to cut. It is important to emphasise that the toolpath (the actual cutting moves your machine must make to leave your intended shape) is rarely, if ever, a direct conversion of the original artwork. The toolpath must be created taking into account a complex interaction of the material, your CNC machine's capabilities and the shape of your cutting tool.
"Sculpture, per se, is the simplest thing in the world. All you have to do is to take a big chunk of marble and a hammer and chisel, make up your mind what you are about to create and chip off all the marble you don’t want." - Paris Gaulois, 1879.
Toolpaths are therefore generated from source vector artwork but once created they are almost entirely indepenendent of the artwork that created them. Moving, editing or even deleting the source artwork used to generate a toolpath will not affect the toolpath - it must be actively re-calculated to reflect any changes.
This is a carefully considered Vectric design principle - although you may be prompted that a significant alteration to your job has occurred - your toolpaths will never change automatically 'behind your back'!
That said, toolpaths do retain a handy reference to the artwork that created them. If you choose to edit a toolpath it will try to locate it's orginal source artwork and re-select it. At this point you can simply recalculate it to reflect any changes you have made to that source artwork, but you can also choose to select additional or entirely different artwork.
Preview
As we've discussed, the actual motion of your CNC machine (the toolpath) required to cut al shape can be complex and difficult to interpret.
Luckily your software provides an extremely accurate preview of any toolpaths that you create by simulating them in a block of virtual material. In the Example Project we will use the Toolpath Preview to verify that the toolpaths are producing the shapes we want (and we can easily corrected them if not)!
This simulated preview is a hugely beneficial step that ensures you minimise costly mistakes in the real world (we all make them from time to time) but it also allows you to check the surface finish you can expect from different strategies under different conditions.
The Toolpath Preview uses exactly the same data that will be sent to your CNC machine. You can be confident that any cutting and surface finish issues that occur at the machine but which are not visible in the Toolpath Preview are almost always caused by a physical problem with the machine setup or tooling, which makes finding and fixing them a lot quicker!
Exporting the toolpath
Now we will be ready to export the toolpath, in the right format, ready to be loaded into our CNC machine's controller. Saving the toolpath will make use of a Post-Processor that is specific to your CNC machine. It will translate the movements contained in the toolpath into a toolpath file that is in the specific format required by your CNC machine's controller to load and run.
04. Getting Started - One-Time Setup
One-time setup
Before we can begin, however, we must complete a couple of one-time steps to ensure your newly installed software is correctly configured. We will start by showing you how to log in to Vectric's online portal, V&Co. Here you will be able to download many other tutorials & projects, clipart packs and software updates. It is also the place you will find your personal product license code and you can return to it any time should you need to recover this licence information or use the main product installer again for any reason in the future. We will also use V&Co to access our online Machine Database. We can use this to automatically configure your software for the make and model of your CNC machine. Licensing and configuring your software typically only needs to be completed once and if you are online they can both be completed almost entirely automatically with just a few clicks.
Licence Management & Your V&Co Account
It is important that your investment in our high quality CNC software is protected and that Vectric can continue to create great software in the future - you will, therefore, have a unique personal licence for the software that you have purchased.
This licence is associated with your Vectric V&Co account, and can be accessed at anytime via https://portal.vectric.com. To log in to your V&Co account you will need to use the email address (which must be uniquely yours) and password that you registered with us when your account was created - please keep these details safe. Your registered email address is the way by which we can verify your ownership of the software.
Important Note: you can reset your password at any time using your registered email account and the forgotten password link provided on the V&Co log in page. If you need to change your registered email address it is important to do this before you lose access to the one to which the software is registered. If you can no longer access your registered email, you will need to contact us directly at support@vectric.com but please note that you will now need to be able to provide independent and alternative proof of your identity and purchase.
Within your V&Co account there is a unique digital code for each piece of Vectric software you have purchased. When you first run our software on your laptop or PC you will be prompted to provide this information. If you are installing onto a computer that is online (i.e. with unrestricted internet access available) you can complete this process almost entirely automatically - this is the fastest and easiest method.
The software will simply launch your web browser and prompt you to log in to your portal account. The software will then show the appropriate license that is available to be linked. Simply accept the link and you're good to go!
Once you have completed this process after initial install you will not be required to do it again unless you change computers or need to re-install the software afresh. Your software is now uniquely licenced to you and your details will always be shown in the main interface - even when you are offline, or online but not logged-in.
You can also log into your V&Co account from within the software at any time when you are connected to the internet to enable additional online features and services such as your clipart collection or online tool database.
When logged-in, your software will indicate this in the top right corner of the main window. Please note, the one-time licensing of your software and routinely logging in when using your software are independent concepts. Your personal product licensing is unaffected by your V&Co logged-in status.
We have also ensured that you can complete the software licensing process without having a live internet connection. The process is less automatic and details of the steps can be found here.
CNC Machine Tool Configuration
The software supports hundreds of different types of CNC machine, so the the next thing we will need to do is configure the software for your particular make and model. Correct configuration comprises two elements - appropriate tool settings in the tool database for your CNC machine and setting the 'translation' file (the Post-Processor) needed to create a toolpath file that your specific machine tool controller can understand.
Tool Database
Configuring the software will create a default tool database with tool definitions include cutter movement speeds ("feedrates") that *should* be a reasonable starting point for you to edit the entries for the tool types that you have, according to the recommendations from your CNC machine manufacturer for each material. Appropriate tool settings are the result of a complex interaction of the tool's shape and design, the nature of the material you intend to cut and the strength and power of your CNC machine. Don't use any default settings without first considering whether they are appropriate for your circumstances.
We will look at the Tool Database in more detail in the Toolpath Creation section below.
Post Processors
Your software can create toolpath files for hundreds of different CNC machines and controllers. To achieve this, the software creates an internal representation of a toolpath. Only when this toolpath is saved does it get 'translated' into the specific format required by your CNC machine.
The translation instructions are contained in file called a Post-Processor (because it *processes* the toolpath *after* it has been created).
Post-Processors also determing whether the toolpath movements will be presented to the machine using metric or imperial units. This must typically match the units mode you have set on your CNC machine's controller (seek advice from the manufacturer if needed). Note, however, it doesn't matter what units where used to create the original toolpath within the software - any required conversion is automatically applied when the toolpath is saved through the Post-Processor.
Job Setup - Axis Orientation
Our software is specifically designed for 3-axis CNC Machines (with additional support for an optional rotary axis). As you look at your CNC machine, the normal conventional is that left and right movement is controlled by the X-axis, forward and backward movement controlled by the Y-axis and up and down movement is controlled by the Z-axis.
In our software the width of your job will typically be equivalent to the X-axis of your CNC machine and the height of your job to its Y-axis.
Be aware that some machines are orientated so that the X & Y axes are swapped as you look at them - left to right movement may be controlled by the Y-axis and vice versa.
Use your machine's control software to jog your machine independently in each axis to make sure your expectations are correct.
Although unusual, it is possible that some post-processors will swap the X & Y toolpath coordinates after you have created your toolpaths - effectively changing the apparent orientation of you job - but this is only recommended for users who are confident of their machine's configuration and usage and not recommended for the majority of users who might not be aware of the other issues this can cause. Check with your machine tool manufacturer if you have any doubts.
It can help Orientate yourself so that when you stand before the machine, when you jog the machine to move to a higher X position, it is moving Left to Right infront of you. This can help visualise how the project design you have made in the software will translate to the bed of your machine.
Software Telemetry
Anonymous data is collected and logged to help Vectric understand how the software is used by our customers. This is an Opt-In system and you will be offered the choice to opt-in or out when you first run the software. You can change your choice at a later date in the Edit Menu - 'Options' Your project will not be included in this data, and only general information is recorded, such as which toolpaths and which vector drawing tools are used the most. Data collected will not be identifiable to which user provided it.
05. Getting Started - Example Project
Cutting a Calibration Pattern
For our quick introduction we are going to us a 2D Profile toolpath strategy to engrave a precisely sized and aligned rectangle, circle and star. This pattern will use all the steps we have outlined in The CNC Workflow. It will also allow us to check that the CNC machine is working correctly using some simple but important features of the design:
- The rectangle, circle & star should not appear warped or distorted.
- The dimensions of the carved shapes should exactly match the design.
- The alignment points of the 3 shapes should not show any discrepancies.
- The star is rotated slightly clock-wise and the carving should match the original orientation of the design with no unexpected reflections in X or Y.
At the end of this guide we will review these checks and suggest some troubleshooting tips if any of them are not as they should be.
Material, Tooling & Hold-Down
The XY dimensions of the design will be 100mm (4") so you will need a piece of material approximately 150mm (6") square or larger.
The precise thickness of material is not too important as the design will simply be carved into its surface at a depth of 1.5mm (1/16"). Any piece that is 3mm (1/8") thick or greater will therefore be fine. An offcut of plywood or mdf board would be ideal.
To avoid any chance of collision with clamps or cutting into a screw, the best starting method to hold down a small piece of material like this is to use double sided tape. Any heavy duty 'carpet' type tape will work, but you may need to experiment to find a brand that secures well, but can also be cleanly removed once the job is complete.
The toolpth will be created based on a V-bit, but the precise tool angles are not important. If you don't have a V-bit tool, then a small (3mm, 1/8" diameter or less) end mill or ball nose tool will also work but the cuts will be the broader so the calibration pattern may be a little bit more difficult to interpret.
Create the Job
- Click `Create a new file` to get started.
This opens the `Job Setup` form. All projects start with a job setup. Here is where we consider the physical dimensions of our design. Note that you do not necessarily need to define the whole material block at this point, just that area needed for your design - the design area can be subsequently positioned anywhere on a larger physical material block using the `XY Datum Position`, which your CNC machine will use as its reference starting point.
Like all forms in the software, you should simply work from the top to the bottom of the `Job Setup` form. Forms are typically laid out with the most significant, non-optional or most commonly updated fields at the top. Sensible defaults are provided for most form fields the first time they are accessed (fields will generally remember their previous setting, once you edit them) so initially you can simply ignore any fields you are not sure about. At the bottom of most forms are the buttons to OK (accept), Apply or Cancel any changes you have made.
- The job setup form allows for projects that will be cut from both sides or using a rotary axis, but for now we will simply select `Single Sided`.
We will set the `Job Size` units according to your preference.
Note that your CNC machine controller will be set to expect toolpaths defined in either metric or imperial units and you will need to refer to your CNC manufacturer to determine your particular setting - the Post-Processor you select later will need to match the toolpath to the controller's requirements but this is entirely independent of the units you prefer for designing within the software - everything will be automatically converted, if necessary, when the toolpath file is created.
- Set the width & height of your new job to both be 150mm (6")
- Set the
- Click OK
Design the Calibration Artwork
Your project needs to start with design drawing. On the left-hand side of the screen there are a number of tabbed panels that provide access to various tools to help you to draw your design.
In due course, we will use our design to begin creating toolpaths for our CNC machine. The functions relating to toolpaths and toolpath strategies are located in another panel on the right-hand side of the screen. Initially this panel is hidden. Once our design is largely complete we will switch our focus to the toolpath panel on the right.
This is the typical workflow when creating a CNC project and so the software interface makes this switching of focus easy and intuitive.
For now let's continue to focus on the tools available in left-hand design panel.
The first thing we will do is create a simple 100mm Square, using the Rectangle tool in the Design Panel on the left. Witht he Rectangle tool open, click into the 3D View to place a default rectangle, and in the Edit Boxes on the Right and Bottom of the rectangle, click into each one and type 100.
This will create your Rectangle to be 100mm x 100mm.
Now press the F9 key on the keyboard, and your Rectangle Vector will now be centered in your work space.
Create our First Toolpaths
Now that our design drawing is complete we are ready to consider what toolpath strategy we should use to cut this shape accurately and efficiently.
The software interface can automatically hide the design tools panel and show the toolpath strategy tools panel using the 'Switch to Toolpath commands' button.
- Click on the 'Switch to Toolpath commands' button at the top of the 'Design' tab.
The toolpaths tab will now open on the right-hand side of the software. Here you will find all the tools relating to the creation, editing and saving of toolpaths.
Selecting the most appropriate toolpath strategy for a particular job is one of the toughest aspects of initially learning how to use your CNC effectively. Over time you will explore the different strategies available within this tab and our extensive tutorials and practical examples will to understand what each is used for.
For now we are going to use just the first strategy availble under the Toolpaths Operations - this is the Profile Toolpath.
Click on the Profile Toolpath button to open the 2D Profile Toolpath form.
Saving and Loading the Project
At this point we should probably save our project. Saving the project document using the File->Save menu, or the Ctrl+S shortcut-keys, is just like saving any other conventional application document (i.e. Microsoft Word etc.) and it will include all of your 2D design elements, 3D models and toolpath strategy settings in a `*.crv` or `*.crv3d` file. This is the file that you can come back to any time at a later date to continue your work or to duplicate as the basis of a new project.
Note that this is *not* the file that your CNC machine will read. Saving Toolpaths (see below) is the indepenendent process by which you specifically save the file from this project that your CNC machine needs. It may be helpful to think of the toolpath saving process as more like creating PDF files *from* your Word document - PDF files aren't typically reloaded or edited but they are ready for 'printing'.
Previewing the Toolpath
Before we begin getting our toolpath files over to our CNC machine there is still a *very* important step for us to do in the software. We can preview exactly how our CNC machine will move and what the material should look like after each toolpath is completed using the Preview Toolpaths command.
Saving Toolpaths - Post Processing
You now need to Post Process your Toolpath to save your toolpath out into a file which your CNC Machine will be able to read.
In this guide we will assume that you have completed the "Machine Configuration" Process either Manually or using one of the existing Online Configurations as seen here.
With that step complete, you just need to now open the "Save Toolpath" form, using the bottom right most icon in the Toolpath Panels icons.
Make sure your machine is currently selected in the Machine
Running Your Toolpath
Every CNC machine and controller is different. At this point you will need to refer to your CNC machine manufacturers instructions for the details of running your toolpath file, but we can provide some generally applicable information about the typical process you should expect.
Secure your material
Your piece of material will need to be secured to the machine's bed. This is typically done by clamping, screwing or gluing your material down (larger or more sophisticated machines may have vacuum hold-down). In the first two cases you must be very careful to avoid cutting into your clamps or screws. As we noted in the Job Setup, the toolpath file does not have to be the same size as the material so the simplest way to avoid clamps and screws is to make sure your job dimensions (and thus your toolpaths) are no larger then the unobstructed area of your material and that it is correctly positioned within this region.
Set your origins (datums)
The movements of all toolpaths are relative to the `XY datum position` you selected when you initially created your job (in our example we set the bottom-left corner, but it can also commonly be the center of your design), these are also often referred to as "origins". Now you must indicate to your CNC machine controller where this datum point is physically located on your material. This process is usually referred to as "setting the XY datum", "setting the XY origin" or "zeroing X & Y".
In effect, setting the XY datum will position where your toolpath will be cut on your material.
You will also need to indicate to your controller how deep into the material your toolpath will cut - the equivalent of positioning your toolpath within the material. This is often known as "setting the Z origin", "setting Z zero" or "zeroing Z".
Again at this point it is important to know what `Z Zero Position` setting you used when you created your Job in the software - in our example we set it to be on the surface of the material, but in some circumstances it is useful to set it to the base of the material block, or your CNC machine's bed.
Because this job was created with the `Z Zero Position` to on the `Material Surface`, you will need to jog your CNC machine so that the tip of the tool is touching the surface of the material and then use its control software to zero the Z position.
Alternatively you may have an automatic Z touch plate or probe to achieve the same result - refer to your CNC manufacturer for instructions on this step.
Note: when wanting to do a test 'air cut' this is your opportunity to back your CNC machine upward in Z to a point in the air where the toolpath's maximum depth will not contact any physical material and set your Z zero 'in the air' instead. Running your toolpath with the Z origin in the air like this is a very useful test of movements of a toolpath if you have any doubts or uncertainties about your setup or toolpath settings before any real cutting.
At this point your CNC machine should be in a state where its position indicators would read X=0, Y=0 & Z=0 when the tip of the tool was at the position you defined when you created your origin job - in our example this would be at the bottom-left corner of the area we will cut and just touching the top surface of the material.
Load your toolpath File
Ready to go?
You should always consider a visual check of at least the initial start point and feedrates of an untested toolpath with an 'air cut' (see note above). Pay particular attention to the movement that will form the first full-depth, full-width cut - as this will be when the tool and CNC machine are under the most stress - to ensure that it looks appropriate for the tool and type of material you are intending to cut.
When you first start using your CNC it is worth considering keeping a simple written checklist at your controller. An example might be:
Have I:
- Run an 'air-cut' to check initial movement?
- Checked the material is firmly secured?
- Checked right type and shape of tool is fitted for this toolpath?
- Set the X,Y origin?
- Set the Z origin?
- Turned the spindle on (if not automatically enabled by your CNC machine's controller)?
OK, time to cut!
Always run any toolpath with untested or unverified tool settings with extra care and caution. When cutting with new tools and or in new materials seek advice from your CNC machine or tool manufacturer about the appropriate feeds and speeds for your machine and tooling.
Check the Calibration Cuts
Troubleshooting
Scale / units
My Design is cutting out much smaller/larger then it designed for.
Double check what distance your machine moves when you manually command the controller to jog from X=0 to X=1
The distance it travels should be exactly 1 Inch or 1mm.
If it moves the 1 Inch then you need to ensure that when you save your toolpaths from Cut2D Desktop that you use the Inches Post Processor.
Likewise, if it moves 1mm, then use the MM Post Processor instead.
If it moves a different distance, instead of one of these options, then the machine calibration needs to be reviewed with help from the machines supplier.
Double check this on each of the X Y and Z Axis's, and it must move the exact same distance on all Axis.
Backlash
Backlash is a physical issue in the machine where an Axis will move the correct distance for a cut, but then loosness on the Axis motor or screw barings will allow it to slip.
This can build up over time for the machine to graducally become more and more misaligned over the duration of a toolpath. Commonly if you see inaccuracy in cuts only in one direction then it will be backlash issues on that one Axis.
Report the issue to your machiine supplier for advice on how to elliminate backlash in your hardware.
Inverted axis
The most common indicator of an inverted axis is text being mirrored in a single direction. A rarer case can be when the router will raise when it should plunge, resulting in it cutting air, even when Z Zero is correctly set. This can be due to a number of factors, such as:
- Hardware Wiring.
- Controller Setup.
- Post Processor setup.
The Hardware wiring is always the first thing to check in these cases, to ensure that the machines hardware is all connected as intended, and there are no wiring issues. If the positive and negative terminals on a motor are reversed then the motor can go in reverse.
The controller setup is part of the controllers calibration, and if values are reversed here, it can cause the motors to then work in reverse.
Post Processor setup can sometimes require the reversing of an Axis. This will have been required by the machine supplier to fit their machines configuration. The Post Processor should usually not be reversed manually, and is setup to fit the machine suppliers specifications. In rare cases where it is needed to be changed to suit a CNC machines which cannot be corrected with the above points then Editing the Post Processor can help.
06. Intermediate - 2D Design and Management
Ultimately the point of all these different types of objects is to allow you to create the toolpaths you need to cut the part you want on your CNC. This may mean that they help you to create the basis for the 3D model or that they are more directly related to the toolpath such as describing its boundary shape. The different applications and uses for these 2D items mean that organization of them is very important. For this reason Cut2D Desktop has a Layer function for managing 2D data. The Layers are a way of associating different 2D entities together to allow the user to manage them more effectively. Layers will be described in detail later in the relevant section of this manual. If you are working with a 2 Sided project you can switch between the 'Top' and 'Bottom' sides in the same session, enabling you to create and edit data on each side, and using the 'Multi Sided View' option you can view the vectors on the opposite side. 2 Sided Setup will be described in detail later in the relevant section of this manual.
Vectors
Vectors are lines, arcs and curves which can be as simple as a straight line or can make up complex 2D designs. They have many uses in Cut2D Desktop, such as describing a shape for a toolpath to follow or creating designs. Cut2D Desktop contains a number of vector creation and editing tools which are covered in this manual.
As well as creating vectors within the software many users will also import vectors from other design software such as Corel Draw or AutoCAD. Cut2D Desktop supports the following vector formats for import: *.dxf, *.eps, *.ai, *.pdf, *skp and *svg. Once imported, the data can be edited and combined using the Vector Editing tools within the software.
08. Intermediate - Creating a Rotary Job
Z Origin
Tip:
XY Origin
Orientation
Vector Layout
Choosing stock material
09. Intermediate - Simple Rotary Modelling using 2D Toolpaths
Creating rotary toolpaths
Spiral toolpaths
10. Advanced - Rotary Machining and Wrapping
Cut2D Desktop can 'wrap' flat toolpaths around a cylinder to provide output to CNC machines which are configured with a rotary axis / indexer. The image below shows a flat toolpath wrapped around part of a cylinder.
Cut2D Desktop can also visualize a wrapped model within the program by drawing the shaded composite model wrapped.
Cut2D Desktop also has the ability to draw the toolpath simulation wrapped. Although this is very useful for getting a feel for how the finished product will look, it is important to realize that the wrapped simulation may not be a 100% accurate representation of how the finished product will look. An example of potential difference would be if you drilled holes in your rotary job. In the actual work piece these will obviously just be round holes, in the wrapped simulation these may appear as distorted ovals due to the 'stretching' process which takes place when we wrap the flat simulation model for display.
This will now open a menu where you can press the + button under 'Associated Post-Processors' to access all of the available post-processors within the software and choose the appropriate wrapped post-processor for your machine configuration.
15. Advanced - Post-Processor Editing
G-Code Output
T1 M6
G17
G0 Z4.5000
G0 X0.0000 Y0.0000 S12000 M3
G0 X2.4567 Y7.8342 Z0.2500
G1 Z-0.0500 F5.0
HPGL Output
IN;PA;
PU2496,7960;
PD2496,7960;
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
PU2496,7960;
PU2496,6096;
Post Processor Sections
File Comments
+ History
+ Who When What
+ Tony 14/07/2006 Written
Global File Statements
Statement | Result |
MAXIMUM_ROTATION | MAXIMUM_ROTATION = "90" This will limit the largest rotation possible in a rotary Axis. Larger turns will be broken down into multiple smaller turns. the largest value should be 179 while 90 is a reasonable safe choice. |
MAXIMUM_LENGTH | MAXIMUM_LENGTH= "90" This will limit the largest straight movement possible to 90 units. This can be used to break up long moves into smaller sections which some controllers use to manage their feedrates. |
RAPID_SPEED | Used to define a fixed Rapid speed to use when performing any Rapid moves which call for a Feedrate value |
FIRST_TOOLPATH_NEW_SEGMENT = YES | When FIRST_TOOLPATH_NEW_SEGMENT = YES is specified the Post Processor will output TOOLCHANGE and NEW_SEGMENT immediately after the header for the first toolpath. This allows to avoid some code repetition between header and new segment Normally the NEW_SEGMENT Code block is only called on the second or later toolpath in the event that the new segment uses a different Spindle Speed while using the same tool as the previous block. This can allow for condencing commands if the Header, TOOLCHANGE and NEW_SEGMENT contain many repeat commands. |
Tape Splitting Support
For example a command of:
would lead to...
Output will be split into multiple files of a maximum of 1000 lines (+ however many lines in there are within the footer section of the post processor), if a retract move exists after line 900 (1000 – 100), the file will be split at that move. If the file was called "toolpath" the split files would be named toolpath_1.tap, toolpath_2.tap etc. The first toolpath output will be "toolpath_ 1.tap" there will be no file named "toolpath" without an index number, (as INDEX_ON_FIRST_FILE=YES is used), unless the file was less than 1000 lines long, in which case the file would not be split.
Line Terminating Characters
LINE_ENDING="[13][12]"
Block Numbering
Variables
| Tool diameter. | |
Format of Variables
where
VO= Variable output for example X, XF or F.WO= When output, A=Always, C=Only when changed.CS= Character string output before value .VF= Value format, determines the format that the value is output with.MX= Multiplier Value.
A typical variable
VAR- This line is a Variable.- Variable Name.
- Equals Sign.
A= Always output value,C= Only output value when it changes- Vertical Bar - Parameter separator.
Formatting the Output Value
| Values is always output with a separator character ( in practice this would only change the output value if the value is set to output integer values only) | When output is set to integer only, separator charactor is not appended to value. |
Default | Example |
Multiplier Value
Post Processor Blocks
HEADER
begin HEADER
"Commands"
Home Position Information
- Home X = [XH]
- Home Y = [YH]
- Home Z = [ZH]
- Tool Number = [T]
- Tool name = [TOOLNAME]
Initial cutting speeds
Spindle Speed
- Spindle Speed = [S] R.P.M.
SPINDLE_ON
begin SPINDLE_ON
"Commands"
TOOLCHANGE
begin TOOLCHANGE
"Commands"
- Previous Tool Number = [TP]
- Tool Number = [T]
NEW_SEGMENT
begin NEW_SEGMENT
"Commands"
INITIAL_RAPID_MOVE
begin INITIAL_RAPID_MOVE
"Commands"
This Block is Disabled when Keep out zones are enabled in a Project.
Refer to STRAIGHT_RAPID_MOVE below.
RAPID_MOVE
begin RAPID_MOVE
"Commands"
FIRST_FEED_MOVE
begin FIRST_FEED_MOVE
"Commands"
FEED_MOVE
begin FEED_MOVE
"Commands"
FIRST_CW_ARC_MOVE
begin FIRST_CW_ARC_MOVE
"Commands"
"Commands"
FIRST_CW_HELICAL_ARC_MOVE
"Commands"
CW_ARC_MOVE
begin CW_ARC_MOVE
"Commands"
CW_HELICAL_ARC_MOVE
begin CW_HELICAL_ARC_MOVE
"Commands"
FIRST_CCW_ARC_MOVE
begin FIRST_CCW_ARC_MOVE
"Commands"
"Commands"
"Commands"
CCW_ARC_MOVE
begin CCW_ARC_MOVE
"Commands"
begin CCW_HELICAL_ARC_MOVE
"Commands"
FOOTER
begin FOOTER
"Commands"
SPINDLE_ON
The Spindle On section is used after the Header and allows the Spindle on commands to be used in a combination Milling/Laser Post Processor.
If Spindle on commands are used in the Header, this Block should not be included.
begin SPINDLE_ON
"Commands"
- M3 for Spindle On
- [S] For Spindle Speed
Jet Support Sections
JET_TOOL_POWER
begin JET_TOOL_POWER
"Commands"
JET_TOOL_ON
begin JET_TOOL_ON
"Commands"
JET_TOOL_OFF
begin JET_TOOL_OFF
"Commands"
Drill Banks
These sections are for supporting drill banks.
A drill bank is a tool that has multiple individual drills arranged on horizontal and vertical arms. These can be engaged (extended) or disengaged (retracted) individually prior to plunging, to facilitate efficient drilling of hole arrays.
The CAM software can output drill bank instructions in one of two modes:
- Pattern-based mode (for controllers that accept a bitmask or combined drill selection command)
- Per-drill mode (for controllers that accept individual drill commands)
The two modes are mutually exclusive, and each make use of different sections. As such, the set of sections defined in the post processor determines the mode of output. Both use SETUP_DRILL_BANK and FINAL_DRILL_BANK_ACTION, but pattern-based mode uses only DRILL_BANK_PATTERN, whilst per-drill mode uses only DRILL_BANK_EXTEND_DRILL and DRILL_BANK_RETRACT_DRILL. Failure to define SETUP_DRILL_BANK and FINAL_DRILL_BANK_ACTION, or defining an invalid combination of DRILL_BANK_PATTERN, DRILL_BANK_EXTEND_DRILL, and DRILL_BANK_RETRACT_DRILL will prohibit the saving of drill bank toolpaths.
SETUP_DRILL_BANK
+ Commands output when entering drill bank mode
begin SETUP_DRILL_BANK
"Commands"
For an example of a SETUP_DRILL_BANK section, see the file: Weinig_OSAI_DB_mm.pp
Commands that are output at the start of every block of drill bank moves. This can be at the very start of the output if the first toolpath uses a drill bank.
DRILL_BANK_PATTERN
+ Commands output on pattern change
begin DRILL_BANK_PATTERN
"Commands"
For an example of a DRILL_BANK_PATTERN section, see the file: Weinig_OSAI_DB_mm.pp
Commands that are output on pattern change (pattern-based mode only).
+ Commands output on drill extend
begin DRILL_BANK_EXTEND_DRILL
"Commands"
For an example of a DRILL_BANK_EXTEND_DRILL section, see the file: SERON_OSAI_helisa_DB_mm.pp
Commands that are output on drill extend (per-drill mode only).
+ Commands output on drill retract
begin DRILL_BANK_RETRACT_DRILL
"Commands"
For an example of a DRILL_BANK_RETRACT_DRILL section, see the file: SERON_OSAI_helisa_DB_mm.pp
Commands that are output on drill retract (per-drill mode only).
DRILL_BANK_FINAL_ACTION
+ Commands output when exiting drill bank mode
begin FINAL_DRILL_BANK_ACTION
"Commands"
For an example of a FINAL_DRILL_BANK_ACTION section, see the file: Weinig_OSAI_DB_mm.pp
Commands that are output at the end of every block of drill bank moves.
Variables
Variables Available:
Var Name | Output Using | Value |
| Bitwise |
| Bitwise |
| Bitwise |
| Formatted Drill List |
DRILL_LIST Variable
The DRILL_LIST variable is often required if the controller requires a specific formatting for output rather than just a binary representation of engage drills.
The format for the DRILL_LIST variable is:
var DRILL_LIST = [short_name|prefix|separator|first_separtor]
where
prefix: Text before each drill numberseparator: Text between subsequent drillsfirst_separator: Text between first and second drill
For example, if drills 1, 3, 5 are engaged with the format [DL|D|,| ]. The the output is:
D1 D3,D5 (space after first, commas after rest)
Additional Variables
| The single drill number being extended or retracted. |
Cutter Compensation
Cutter compensation (cutter comp) tells the CNC controller to offset the toolpath left or right by the tool radius, it can be used to adjust for any difference in radius between the tool the software was programmed with and the actual tool to be used, often employed to account for tool wear.
Cutter comp is an optional feature tied to profile toolpaths and only available with the Advanced Machining Module. When enabled, the post-processor embeds compensation commands into the lead move output lines, rather than outputting them as separate sections.
Cutter compensation uses an **inline string variable** approach to adjusting output:
- Three paragraphs define what to output for left/right/off
- At output time, the appropriate paragraph is rendered into a string variable (
CUTTER_COMP`) - That variable is referenced inline in lead move output lines (e.g.,
FEED_MOVE,FIRST_FEED_MOVE,CCW_ARC_MOVE) - After the lead move is output, the variable is cleared back to empty
So in order to use Cutter Compensation you must define three sections:
begin CUTTER_COMP_LEFT
begin CUTTER_COMP_RIGHT
begin CUTTER_COMP_OFF
Example
"G41"
"G42"
"G40"
"[CUTTER_COMP]G1[X][Y][Z][F]"
begin FEED_MOVE
"[CUTTER_COMP]G0[X][Y][Z]"
The above example would give the following output for a profile toolpath with left cutter compensation enabled:
G0 X0.000 Y0.000 Z30.000 ← rapid to start (no comp yet, [CUTTER_COMP] is "")
G1 X0.000 Y0.000 Z-5.000 F500.0 ← plunge
G41 G1 X10.000 Y0.000 Z-5.000 F1000.0 ← first feed move with comp LEFT
G1 X20.000 Y0.000 Z-5.000 F1000.0 ← subsequent moves (comp unchanged, variable is "")
G1 X20.000 Y10.000 Z-5.000 F1000.0
G1 X10.000 Y10.000 Z-5.000 F1000.0
G40 G1 X0.000 Y.000, Z-5.000 F1000.0 ← comp OFF at end of profile
G0 X0.000 Y0.000 Z30.000 ← retract (no comp, variable is "")
FEED_RATE_CHANGE
begin FEED_RATE_CHANGE
"Commands"
FIRST_PLUNGE_MOVE
begin FIRST_PLUNGE_MOVE
"Commands"
PLUNGE_MOVE
begin PLUNGE_MOVE
"Commands"
RETRACT_MOVE
begin RETRACT_MOVE
"Commands"
DWELL_MOVE
begin DWELL_MOVE
"Commands"
INITIAL_STRAIGHT_RAPID_MOVE
begin INITIAL_STRAIGHT_RAPID_MOVE
"Commands"
Used to define initial commands when outputting a Keepout Zone Rapid move. This can be used to replace the standard RAPID_MOVE command to use G1 with a given rapid feedrate instead of a G0 move when the machine does not interpolate is G0 commands.
FIRST_STRAIGHT_RAPID_MOVE
begin FIRST_STRAIGHT_RAPID_MOVE
"Commands"
- G00 [XH] [YH] [ZH] Rapid to the next X,Y,Z position.
- F400 An example of a fixed Feedrate to use for the first in a series of Rapid moves.
Used to define the first Rapid commands when outputting a Keepout Zone Rapid move. This can be used to apply additional commands in addition to the typical G0 XYZ commands, such as a fixed feedrate to use for this move.
This variable is only needed if the the first rapid move requires an additional command which can't be included in every standard STRAIGHT_RAPID_MOVE
STRAIGHT_RAPID_MOVE
begin STRAIGHT_RAPID_MOVE
"Commands"
Used to define commands when outputting a Keepout Zone Rapid move. This can be used to replace the standard RAPID_MOVE command to use G1 with a given rapid feedrate instead of a G0 move when the machine does not interpolate is G0 commands.
Special Characters
- [10] Outputs a line feed.
For our example, we will add a tool-change section to this post processor. Go to the Machine Configuration option under the machine menu.
In the Associated Post Processor section, click on the (+) icon and scroll down the list to locate your Post Processor in the list.
Right click on it and select Customise
A new copy of the Post Processor will appear at the top of the list with a pen icon next to it.
Right click on this copy and select Open File Location
This will open the Windows folder with the .pp Post Processor file itself which you can then directly edit if you need to adjust commands to fit your particular machine setup. These .pp Post Processor files can be edited in any standard Text Editor software
To do this:
POST_NAME =
FILE_EXTENSION =
and alter these accordingly.
FILE_EXTENSION = "tap"
to make them read:
FILE_EXTENSION = "nc"
Tips And Tricks
