Right Mouse Click Menu
Clicking the ►RIGHT hand mouse button in different places in Cut2D Desktop will display a menu with choices which depend on the area of the software being clicked on and/or the object or selection that the mouse cursor is positioned over. This page details some of these areas and the menus that you will see when RIGHT mouse clicking.
2D/3D View
Activate Layer of Selection
Appearance
This will bring up the following tool Box.
Appearance
This slider will allow you to increase/decrease the amount of fading applied to this Bitmap when it is not the currently selected item.
Component
Text
Remove From Curve:
Break Block into Lines:
Convert to Vectors:
Layer and Side Operations
  • Copy to allows you to copy an object onto an existing Layer/Level/Sheet or to create a New one to copy it onto.
  • Move to gives you the same choices but moves the original object rather than making a copy.
  • Other Side copies the selected objects onto the other side in a two-sided job. The objects will be transformed so that they match up when looking through the material.
  • Move to Front/Back is 2D View Exclusive and will bring items to the front or rear of other items on that same layer.
  • Move to Up/Down is 3D Exclusive and will Raise or Lower the Components posiotion within its current Level.
Span Editing Menu
  • Convert the span to a Line, Bezier (curve) or Arc
  • Insert a Point
  • Cut the Vector at that point
  • Delete the Span
  • Insert a Midpoint
  • Keep Bezier Tangency, which will fix the start and end directions of Bezier curves when they are being dragged directly, can be toggled on or off.
Node Editing Menu
  • Delete the Point
  • Smooth it
  • Insert a point at a virtual midpoint
  • Cut the vector at that point
  • Change the point to be the Start Point of the vector or extend the vector using the Polyline tool.
  • Horizontal or vertical mirror mode for node editing can be toggled on or off.
Layer Menu
Activate
Show
Hide
Lock
Unlock
Insert New Layer
Delete
Delete this layer
Rename
Rename this Layer
Merge Visible
Select Layer Vectors
Toolpath List Menu
  • Show This,
  • Show Only This,
  • Show All But This
  • Show All With This Tool
  • Show All.
You can Edit, Rename or Duplicate the selected toolpath. The Recalculate submenu allows you to recalculate the selected toolpath, visible toolpaths or all toolpaths with any updated geometry selections.
