Post Processor Editing
G-Code Output
T1 M6
G17
G0 Z4.5000
G0 X0.0000 Y0.0000 S12000 M3
G0 X2.4567 Y7.8342 Z0.2500
G1 Z-0.0500 F5.0
HPGL Output
IN;PA;
PU2496,7960;
PD2496,7960;
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
AA2496,8896,90.000
PU2496,7960;
PU2496,6096;
Post Processor Sections
File Comments
+ History
+ Who When What
+ Tony 14/07/2006 Written
Global File Statements
Statement | Result |
| Rotary: Enables / Disables output of the feedrate F in Inverse Time Feed Mode. In this mode, we're expected to complete a move in one divided by the F number of minutes. In GCode, this would G93 to switch on, or G94 to switch off and use units mode. |
Tape Splitting Support
For example a command of:
would lead to...
Line Terminating Characters
LINE_ENDING="[13][12]"
Block Numbering
Variables
| Tool diameter. | |
Format of Variables
, [Y]
and [Z]
respectively.
where
VO
= Multiplier Value.
A typical variable
VAR
- Equals Sign.
A
= Always output value,C
Formatting the Output Value
Default | Example |
Multiplier Value
Post Processor Blocks
HEADER
begin HEADER
"Commands"
Home Position Information
- Home X = [XH]
- Home Y = [YH]
- Home Z = [ZH]
- Tool Number = [T]
- Tool name = [TOOLNAME]
Initial cutting speeds
Spindle Speed
- Spindle Speed = [S] R.P.M.
TOOLCHANGE
begin TOOLCHANGE
"Commands"
- Previous Tool Number = [TP]
- Tool Number = [T]
NEW_SEGMENT
begin NEW_SEGMENT
"Commands"
INITIAL_RAPID_MOVE
begin INITIAL_RAPID_MOVE
"Commands"
RAPID_MOVE
begin RAPID_MOVE
"Commands"
FIRST_FEED_MOVE
begin FIRST_FEED_MOVE
"Commands"
FEED_MOVE
begin FEED_MOVE
"Commands"
FIRST_CW_ARC_MOVE
begin FIRST_CW_ARC_MOVE
"Commands"
"Commands"
FIRST_CW_HELICAL_ARC_MOVE
"Commands"
CW_ARC_MOVE
begin CW_ARC_MOVE
"Commands"
CW_HELICAL_ARC_MOVE
begin CW_HELICAL_ARC_MOVE
"Commands"
FIRST_CCW_ARC_MOVE
begin FIRST_CCW_ARC_MOVE
"Commands"
"Commands"
"Commands"
Simile alla sezione FIRST_CCW_ARC_MOVE, ma relativa agli spostamenti eseguiti anche in Z.
Per un esempio di una sezione CCW_HELICAL_ARC_MOVE, vedere il file: Mach2_3_ATC_Arcs_inch
CCW_ARC_MOVE
begin CCW_ARC_MOVE
"Commands"
begin CCW_HELICAL_ARC_MOVE
"Commands"
FOOTER
begin FOOTER
"Commands"
Jet Support Sections
JET_TOOL_POWER
begin JET_TOOL_POWER
"Commands"
JET_TOOL_ON
begin JET_TOOL_ON
"Commands"
JET_TOOL_OFF
begin JET_TOOL_OFF
"Commands"
FEED_RATE_CHANGE
begin FEED_RATE_CHANGE
"Commands"
FIRST_PLUNGE_MOVE
begin FIRST_PLUNGE_MOVE
"Commands"
PLUNGE_MOVE
begin PLUNGE_MOVE
"Commands"
RETRACT_MOVE
begin RETRACT_MOVE
"Commands"
DWELL_MOVE
begin DWELL_MOVE
"Commands"
Special Characters
- [10] Outputs a line feed.
To do this:
POST_NAME =
FILE_EXTENSION =
and alter these accordingly.
FILE_EXTENSION = "tap"
to make them read:
FILE_EXTENSION = "nc"
Tips And Tricks
- Always make a safe copy of the post processor that you are editing, in case you need to start again from scratch.
- If using a word processor program, such as Microsoft Word, to edit a post processor, make sure that the file is saved as plain text. The file should not contain formatting information.
- If editing post processors on a computer that runs Microsoft Windows 7 or Microsoft Vista, do not edit the files directly within the “Program Files\Product folder\PostP” folder. Always edit the file within your user area and copy the edited file to “Program Files\Product folder\PostP”.
- Use comments when you make changes, a comment is a text that follows a + or a | character. Comments will not be acted upon by the program but can help in documenting changes that you have made and make those changes understandable in the future.
- All Instruction lines must be contained within quote marks.
- If possible, use a text editor that makes use of line numbers; This will make it easier to debug the post processor if there are any errors in the file. The program will check the post processors in the PostP folder when the program starts. If syntax errors are present in the file, an error message will be displayed, showing the line number of the first error encountered.
- Once you have successfully edited a post processor, make a safe copy of it. If you install a later version of the Vectric product that you are using, remember to copy your modified post processor to the PostP folder of the new version of the software. And select your modified post processor, the first time that you save a toolpath, (The software will remember your selection for subsequent actions).
- If you install another version of the software or you upgrade the version of the software, remember to copy your safe copies of your edited post processors to the PostP folder of the new version. Ensure that you select the correct post processor the first time that you post process a file using the new version of the software.
- For later versions of the software, ( V5.5 and above). The post processors should be accessed from within the application, by clicking “File > Open Application Data Folder\PostP folder.
- A customized list of post processors can be created by copying only the post processors required to the “File > Open Application Data Folder\My_PostP folder. If any file with a .pp file extension exists in the “My_PostP” folder, then only the post processors that exist in the My_PostP folder will be displayed in the drop down list of post processors.
Post Processor Naming Conventions
Within the post processors that ship with the products you will see the following terms or abbreviations used:
- Arc or Arcs = The post processor will output true arcs within the design as Arc moves, (G2,G3,Radius of Arc etc.).
- Inc = Arcs are output with centre coordinates incremental to the last move.
- Abs = Arcs are output with absolute coordinate values.
- ATC = The post processor will output Automatic Tool Change (ATC) commands.
- WY = Wrapped out output post processor – Y values wrapped around X axis
- WX = Wrapped out output post processor – X values wrapped around Y axis
- TSnumber = Tape Splitting post processor.
- An optional number is the maximum number of lines that will be output within a single file. Files that exceed this number of lines will be split into multiple files. (See Tape Splitting Support for more details).
- (mm) = The post processor units are Metric.
- (inch) = The post processor units are English (Imperial) inches.
- (*.xyz) = The file extension that the output file will be created with.
