Laser Module
The Laser Module is a paid add-on for VCarve Pro which adds the following additional functionality:
  • The ability to create Laser Cut and Fill Toolpaths
  • The ability to create Laser Picture Toolpaths
  • The ability to simulate a Laser Toolpath
The Laser Cut - Fill Toolpath
The Laser Picture Toolpath
Simulating Laser Toolpaths
test
Burn Rate 50
test
Burn Rate 100
test
Burn Rate 200
