VCarve Inlay Toolpath - Pocket
The VCarve Inlay Pocket Form is used to make adjustments to the Pocket half of a VCarve Inlay you have created.
Start Depth (D)
When Editing the Pocket part of a VCarve Inlay, you will be able to adjust the Start Depth (D) of the toolpath.
This will allow you to drop the Inlay toolpath into an existing Pocket you have cut in the project.
This can help if you are looking to add the Inlay into the bottom of a Bowl you have made for example.
Flat Depth (F)
This is fixed by the original VCarve Inlay Generation and is directly related to the Plug side of the toolpath.
If this requires altering, please delete both the Pocket and Plug toolpaths you have generated and remake them.
Use Clearance Tools
You can add a large area clearance tool here to help remove material more efficiently from the VCarve Inlay Pocket, if you have not already included one in the original toolpath generation.
