Draw Ellipse
![](https://cdn.sanity.io/images/i7cqi3ri/12/5224a33d3024888ee4720d76260bbe85a859b896-238x343.png)
Interactive - Cursor
- Click and drag the left mouse button in the 2D View to begin drawing the ellipse from its corner.
![](https://cdn.sanity.io/images/i7cqi3ri/12/a49dca4b8b1fdeb1a2b6f643ecd3bf29d1154289-420x113.png)
- Holding Alt and dragging creates an ellipse from the middle point.
- Holding Ctrl and dragging creates a circle.
Quick Keys
Default
Specifying Further Properties
- Value X - Creates an ellipse at current dragged height but with set width
- Value Y - Creates and ellipse at current dragged width but set height
- Value W Value H - Creates an ellipse with set width and height
Examples
- 1 x Current dragged height with width (X) of 1
- 1 y Current dragged width and height (Y) of 1.
Exact Size
Editing an Ellipse
To edit an existing ellipse:
- Select the ellipse to modify and open the Draw Ellipse form.
- Click to update the ellipse.
Usable In Both Views
2D View offers a more direct way to view your vectors while 3D Offers more flexability to work with Vectors in 3D Designs and to make use of the Edit Boxes.
