Pocketing Toolpath
![](https://cdn.sanity.io/images/i7cqi3ri/12/814cec4ebc6b0539f975f324083fe74362ea993a-278x754.png)
Cutting Depths
Start Depth (D)
Cut Depth (C)
Tool Selection
In the pocketing toolpath you can select any number of tools you wish to use to perform your pocketing. When multiple tools are chosen then the first tool removes as much material as it can, all subsequent tools in the list will remove as much material as it can from any previously unmachined areas. If multiple tools are selected then the order of the tools in the list should match the order they will run on the machine.
Pass Depth Control
![](https://cdn.sanity.io/images/i7cqi3ri/12/14c9d14e8c1309e1635c6b37d1e56f2668263009-383x562.png)
Specify Pass Depths
Pass Depth List Utilities
Strategy Options
![test](https://cdn.sanity.io/images/i7cqi3ri/12/d63d350296c65d4954ddc41f1c90dc5f0680d1cf-264x213.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/2d93df4980e9a7dbcaf397872c1b5bf40d11959f-264x213.png)
Offset
![test](https://cdn.sanity.io/images/i7cqi3ri/12/c99ba5a9573a1bd991b81121ecd34cde048cf8f4-257x256.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/12/e46b8f3472c17e571d92e1e98370224181722723-352x256.png)
Raster
- Climb (CCW) cutting direction
- Conventional (CW) cutting direction
Raster Angle
Profile Pass
Note:
Pocket Allowance
Ramp Plunge Moves
The cutter can be ramped over a distance into the pocket instead of plunging vertically. This approach reduces heat build-up that damages the cutter and also reduces the load on the spindle and z axis bearings.
Use Vector Selection Order
If this option is checked, ✓ pockets will be machined in the order you selected them. If the option is not checked the program will optimize the order to reduce machining time.
Note:
