Set Size
![](https://cdn.sanity.io/images/i7cqi3ri/12/b2bf66f3c2d8ec0ac5560843dbbd2b52e99ebed1-238x510.png)
Mode
There are two choice of scaling mode:
- Scale selection
- Scale items individually
If scale selection is chosen then the whole selection is scaled as if it were a single group. If scale items individually is chosen then the scaling is applied to each of them as they were all selected one by one.
Anchor
Link XY
Auto Scale Z
Interactive Sizing
The process is:
- Select the vectors
- Click a second time to activate the interactive options - handles on the selection box
- Click and drag on the white handles
Usable In Both Views
2D View offers a more direct way to view your vectors while 3D Offers more flexability to work with Vectors in 3D Designs and to make use of the Edit Boxes.
