Vector Boundary
Offset Boundary
Rubber Band Boundary
test
Offset Boundary only
test
Offset Boundary and Rubber Band together
Usable In Both Views
2D View offers a more direct way to view your vectors while 3D Offers more flexability to work with Vectors in 3D Designs and to make use of the Edit Boxes.
