3D Toolpath Files
Files from Vectric's Cut3D, PhotoVCarve and Design and Make Machinist that include 3D toolpaths can be imported into Cut2D Pro using the main menu command: File ► Import ► PhotoVCarve, Machinist or Cut3D Toolpaths.
The 3D file must first be scaled to the required size before toolpaths are calculated, and then the complete file saved ready for importing into Cut2D Pro. These files can only be moved and positioned inside Cut2D Pro but cannot be scaled.
Positioning
Origin for the 3D data at X0 Y0
Grayscale image moved to middle of job
[object Object]
The 4 corner roses are all copied from a single file
2D window showing thumbnail previews, text and decorative border
3D window previewing the completed job
Options
