Calculation Edit Boxes
As well as the simple numerical calculations, such as 3+(4/5), several of Cut2D Pro's stored values can be accessed by using certain letters (which are not case-sensitive): When used, Cut2D Pro substitutes the character with the appropriate value in the calculation.
Character
Example
Description
W or X
Material Width
w/2=
Half of the material width
H or Y
Material Height
H*2=
Twice the height of the material
T or Z
Material Thickness
t-0.25=
0.25 units less than the material thickness
P
PI (3.141593)
P*10^2=
Area of a 10 radius circle (π.r2)
I
Imperial Conversion
25.4*i=
Converts 25.4mm to inches
M
Metric Conversion
2*M=
Converts 2 inches to millimetres
Feet
2'+10=
34 inches (2 feet and 10 inches)
