File
New
Creates a New Cut2D Pro job.
Open...
Opens an existing Cut2D Pro job
Close
Save
Saves the current Cut2D Pro file over the last saved version of the file.
Save As...
Increment and Save
Print
Print Preview
Print Setup
Import... ►
Export... ►
Export vectors from the job
Exit
Import
Import Vectors...
Import Vector data.
Import Bitmaps...
Import Bitmap data
Import 3D Model or Component
Export
Printing and Print Preview
