Node Editing Mode
The Node Editing tool can be selected from the Editing window or by pressing the Keyboard shortcut N to toggle between Selection and Node Editing modes.
Vectors Selected
Bezier node editing
When the Node Editing tool is active the cursor changes to a Black Arrow indicating that individual points (nodes) and their connecting spans can be edited. Nodes can be interactively moved by clicking and dragging the left mouse button on a node to select and move the node to a new position.
The shape of lines, arcs and Bezier (curve) spans can be edited by clicking and dragging on the nodes or control points to move them. Multiple nodes and control points can be selected and moved by using the multiple selection options such as the Shift key and dragging to make a selection.
The shape of individual spans can also be edited by dragging the span itself using the left mouse button.
Holding down the Ctrl key while dragging an arc or Bezier span will move the entire span rather than change its shape.
The start and end directions of Bezier curves can be fixed when being dragged directly, by toggling on Keep Bezier Tangency mode.
If you right click on nodes or spans a context sensitive popup menu will be displayed which allows you to insert or delete points and nodes, cut the vector, move the start point, etc.
Node editing vectors is a very powerful way to be able to make changes to the vectors in your part.
Mirror mode
Within the right click context menu, there are also two options: Mirror Horizontal / Vertical. With these checked you will see a dashed magenta mirror line appear, dividing the shape in the selected direction:
In normal operation when two or more nodes on opposite sides of a shape
are selected together whilst holding Shift ; dragging one point will lead
to all selected points being moved in the same direction. With mirror mode
selected the opposing nodes will move in the opposite direction away from each other. This will only be in the direction selected, so in Horizontal it would be in X and in Vertical in Y.
Useful Tip
Smart Snapping combined with Distance Snapping or Quick Keys can give more accuracy when dragging nodes.
Usable In Both Views
When in the 3D View
When in the 3D View, node editing will display some additional information when dragging nodes from one position to another.
The X and Y relative move distances will be displayed, showing where the node started and where it is currently.
When the node is released by the mouse, you can type in the exact relative move values you wish to use.
The X value is selected first automatically.
Enter the desired X value, press Tab and then enter the desired Y value, followed by Enter to complete the action.
Lines
Clicking a line span will select both ends and allow you to move that line in X and Y as one object.
The Length of the line span can also be typed in on the field.
This length is measured starting from the first node of the selected span.
Nodes are counted in order from the first node marked with the direction arrow.
Beziers
Each handle of the Bezier curve can be moved and have their relative position adjusted by the fields just like individual nodes.
Unlike Lines, clicking and dragging on the Bezier span will instead dynamically allow you to drag the curve while the ends are locked in position. The Bezier curve handles will dynamically adjust to create the new curve as you drag.
Arcs
With the Arc curve, clicking and dragging will allow you to dynamically change the Radius of the Arc.
You can also enter in the X Y coordinate values for this centre arc handle, with absolute values.
If a value is entered which would put the arc beyond its maximum Radius, then it will automatically stop at its maximum arc.
