Quick Engraving Toolpath
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/bf5a01548b657b486038e0234a0e9681950d0f8f-278x765.png)
This form is used specifically for calculating engraving and marking toolpaths.
Depth / Pressure
When using Conventional Engraving and End Mill cutters the Depth to engrave / mark is specified and this z depth dimension is output in the toolpath file sent to the CNC machine. The 3D Preview of these toolpaths shows the specified depth of engraving.
When using a Diamond Drag marking Tool the Pressure setting is used to pre-load the spring to ensure the tip of the diamond stays in contact with the material surface, especially when marking uneven surfaces. The 3D Preview of the depth these toolpaths will mark using the Angle of the diamond and the Width of the Line.
For example, when using a 90° Diamond Drag Tool with a 0.010 inch Line Width specified. The depth shown in the 3D preview will be 0.005 inch (with 90° the depth = half the line width).
The ratio of Depth to Line Width will change when using diamond drag tools with different tip angles. When the option to use a Nose Cone is selected (see below) the actual depth specified on the form is used when previewing the toolpath in the 3D view.
Strategy
When using the Quick Engraving Form the Stepover for the cutter is specified on the form and is NOT automatically set from the Tool Database.
The selected text or vectors can be Outlined or Filled.
Outline
The tip of the cutter runs on the selected lines engraving / marking the material surface
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/c3f90ac36f9f9eaecfe9f393cd01e807fa97a8ca-428x127.png)
Fill
A pattern is used to engrave / mark inside the selected text or vectors. There are 3 fill pattern options.
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/f7fd077752d3bfc5a1440f7da2f3c9f7e3e91002-428x127.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/f8b9df30af496c79bfd42be38e6afd1b497d5f69-428x127.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/50226eb92a1cdf077b1a51dc46a1fd5e82944000-428x127.png)
Use Nose Cone
A nose cone is often used when engraving or marking material that is not flat. The nose cone is spring loaded forcing it to slide on the surface of the material. The engraving cutter is set to extend / protrude out of the bottom of the nose cone by the depth of engraving / marking required. This is typically set at around 0.010 inches to 0.020 inches.
When the option to use a Nose Cone is selected the actual depth specified on this region of form is used when previewing the toolpath in the 3D view.
Number of Passes
This option runs the cutter multiple times divides over the toolpath pattern.
Immediate Output
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/e833a13a37b5f8e002e28de314e82723350e6259-255x160.png)
Post Processor
Add side to toolpath name
Output direct to machine
