Laser Module
The Laser Module is a paid add-on for Aspire which adds the following additional functionality:
- The ability to create Laser Cut and Fill Toolpaths
- The ability to create Laser Picture Toolpaths
- The ability to simulate a Laser Toolpath
The Laser Cut - Fill Toolpath
The Laser Picture Toolpath
Simulating Laser Toolpaths
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/0cea2ed1ac7879961b28f08832751ad8f60f81b0-300x298.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/7ecc8476432b36c6d1623a5f50ebd3e575e92509-300x299.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/2ec1e5a20becc9f0c0c04fd97fd734d10d65e9e4-300x299.png)
