Document Variables
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/7a3c69017d12e639e9c51ac86bcb6578c1d32596-457x568.png)
Document Variables provide a mechanism for defining values that can be used in Aspire's Document Variables. They can either be created in the Document Variables dialog which is accessible under the Edit menu, or created from any Calculation Edit Box which supports variables by right clicking and selecting Insert New Document Variable from the Popup Menu.
Naming Document Variables
Deleting Document Variables
Using Document Variables
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/46937b20e20901aecc2f85712b048795b71e44ab-260x90.png)
Accessing Document Variables
