Crop Bitmap
Select the image you would like to crop. Then using shift + left click select the closed vectors you would like to use to crop the image. You may select multiple vectors but the image must be selected first. Click the crop bitmap button to clear the image outside of the vector. If multiple vectors are used for the cropping then the crop tool leaves only the area of the image that lies inside the selected contours.
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/b358eaaf5ae9715cc7537eaa818de6c22f92aabf-291x288.png)
