Text On A Curve
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/3e3f3da3f389336da88ca68cd14f0434eb76c9db-243x648.png)
Text Size
Maintain text Size
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/27efa1e5e721bec184869776d955b5ae4e91d7f5-412x93.png)
Scale text to fill curve
Text Spacing
Text Position
Above Curve
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/7fccb946902f4b207b97422ac47667811cc652d5-413x93.png)
On Curve
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/e858d44cb96b7410c821b1af35e77e765e858653-413x92.png)
Below Curve
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/bfb348c5b079b8a09a24474bd8583fd84d1ef38f-413x96.png)
Text on other side
![](https://cdn.sanity.io/images/i7cqi3ri/11_5/3304a2251f1f1c33dab926b6e9c956a0a17680ba-413x92.png)
Offset Distance
Text Alignment
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/07664fec94c0cf65c5acbca1aca8d4775e9347cc-182x96.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11_5/a232102649c1809d000b4c03e138576d8232b725-182x94.png)
