3D Toolpath Files
Files from Vectric's Cut3D, PhotoVCarve and Design and Make Machinist that include 3D toolpaths can be imported into Aspire using the main menu command: File ► Import ► PhotoVCarve, Machinist or Cut3D Toolpaths.
The 3D file must first be scaled to the required size before toolpaths are calculated, and then the complete file saved ready for importing into Aspire. These files can only be moved and positioned inside Aspire but cannot be scaled.
Positioning
![Origin for the 3D data at X0 Y0](https://cdn.sanity.io/images/i7cqi3ri/production/08f9d02f13085d0f75bd2f9f9b10318da539a5ef-300x289.png)
![Grayscale image moved to middle of job](https://cdn.sanity.io/images/i7cqi3ri/production/74d1197d1e8d41b1d3d2b145738434370d9635bb-300x289.png)
![[object Object]](https://cdn.sanity.io/images/i7cqi3ri/production/34de49c9e1d4e062758f8feea7febccdbe024a6e-234x350.png)
![](https://cdn.sanity.io/images/i7cqi3ri/production/8d6fd3cf80a28ce1373e2d14fb86675b9f9f38f4-300x231.png)
![](https://cdn.sanity.io/images/i7cqi3ri/production/2742f3704d70319d8ebd3ded81a66d709c028130-379x231.png)
Options
![](https://cdn.sanity.io/images/i7cqi3ri/production/83d2de7cec4bfefaf3c5ec617c0387c8d0bc1f08-249x425.png)
