Interface
2D View Controls
3D View Controls
Calculation Edit Boxes
Document Variables
File Types
Job Setup - Double Sided
Job Setup - Rotary
Job Setup - Single Sided
Job Setup Form
License Dialog
Migration Dialog
Options Dialog
PDF Export
SketchUp Files
View Controls
View Toolbar
Menus
Edit
File
Gadgets
Help
Model
Right Mouse Click Menu
Toolpaths
View
Drawing
Alignment Tools
Array Copy
Auto Layout Text
Circular Copy
Convert text to Curves
Copy Along Vectors
Copy Operation
Create Fillets
Create Text
Create a New File
Crop Bitmap
Cut Operation
Dimensions
Distort Object
Draw Arc
Draw Circle
Draw Curve
Draw Ellipse
Draw Line
Draw Polygon
Draw Rectangle
Draw Star
Edit Picture
Extend Vectors
Fit Curves To Vectors
Group Selected Objects
Grouping and Ungrouping
Import Bitmap
Import Vectors
Interactive Selection Mode
Interactive Vector Trim
Join Open Vectors
Measure - Inspect
Mirror
Move Selection
Nest Parts
Node Editing Mode
Object Selection Tools
Offset Vectors
Open a File
Overlap Vectors
Paste Operation
Plate Production
Redo Operation
Rotate
Save a File
Set Size
Snapping Options Dialog
Subtract Vectors
Text On A Curve
Text Selection
Trace Bitmap
Trim Objects
Undo Operation
Ungroup Selection
Vector Boundary
Vector Selection Mode
Vector Texture
Vector Unwrapper
Vector Validator
Weld Vectors
Layers
Layer Management
Clipart
Clipart Tab
Modeling
Add Draft to Model
Baking Components
Clearing or Splitting Components
Component Properties
Component Tree
Create Component from Bitmap
Create Component from Visible Model
Create Shape
Create Texture Area
Create Zero Plane
Emboss Component
Export Model as an STL File
Extrude and Weave
Offset Model
Replace Below
Scale Model Height
Sculpting
Slice Model
Smooth Components
Turn and Spin
Two Rail Sweep
Toolpaths
2D Profile Toolpath
3D Finish Toolpath
3D Rough Toolpath
Array Copy Toolpath
Create Job Sheet
Delete Toolpath
Drilling Toolpaths
Duplicate Toolpath
Edit Toolpath
Estimating Machining Times
Fluting Toolpath
Inlay Toolpath
Laser Cut And Fill
Laser Picture
Load Toolpath Template
Material Setup
Material Setup - Flat
Material Setup - Rotary
Merged Toolpath
Moulding Toolpath
Photo V-Carve Toolpath
Pocketing Toolpath
Preview Toolpaths
Prism Carving Toolpath
Quick Engraving Toolpath
Recalculate All Toolpaths
Save Toolpath Template
Save Toolpaths
Texture Toolpath
Tool Database
Tool Database - Name Format
Toolpath List
Toolpath Templates
Toolpath Tiling Manager
V-Carve Toolpath
Vector Selector
Preinstalled Gadgets
Celtic Weave Creator
Create Rounding Toolpath
Drag Knife Toolpath
Job Setup Sheet Editor
Keyhole Toolpath
Wrapped Fluting Layout
Wrapped Spiral Layout
Modules
Laser Module
VTransfer
User Guides
2D Design and Management
3D Design and Management
3D Toolpath Files
Crash Handling
Creating a Rotary Job
Frequently Asked Questions
General Workflow
How to Get Started
Interface Overview
Modelling 3D Rotary Projects
Post Processor Editing
Rotary Machining and Wrapping
Two-Sided Machining
Close Menu
Open Menu
What's New!
Keyboard Shortcuts
Single Page
User Guide
Vectric Website
Tutorial Videos
User Forum
Create Zero Plane
Creates a component that is the size of your job setup with a height of Zero.
