View Toolbar
![[object Object]](https://cdn.sanity.io/images/i7cqi3ri/production/1b00c127615dbc8061a68a01e4656b2cd618208b-531x29.png)
Snapping Toggle Options
![]() | Snap to geometry |
![]() | Smart Snapping |
![]() | Snap to Grid |
View Controls
![]() | Toggle Pan / Twiddle View |
![]() | Zoom to box |
![]() | Zoom to drawing |
![]() | Zoom to selection |
Toolpath Drawing Toggle
![]() | Toggle 2D Toolpath Drawing |
![]() | Toggle solid 2D Toolpath Drawing |
3D Drawing
![]() | Toggle drawing of material block |
Tile 2D & 3D View Windows
Two-Sided Machining
Rotary Machining
When you are working on a rotary job an additional icon will appear. This button allows you to toggle the 3D view between wrapped display mode and flat display mode.
![]() | Toggle Wrapped 3D view. |
