Tool Database
![](https://cdn.sanity.io/images/i7cqi3ri/translated/c0a87659be883ff4b907f9e41bb4b06a574f9876-681x648.png)
The Tool Database can be accessed from the button through the various Toolpath forms. You can open the Toolpaths Tab button or through the Toolpaths menu.
Overview
- Tool geometry entities (organised hierarchically in the tree).
- List of Materials (Managed through the Material Management dialog).
- List of Machines (Managed through the Machine Management dialog).
- Cutting Data set for each tool geometry. This includes the Cutting Parameters, and Feeds & Speeds, and are defined per machine / material.
- Tool geometry: This is the physical properties of the tool such as the diameter, tip radius, etc...
- Cutting data: These include the Cutting Parameters and Feeds & Speeds of the tool. These values are defined for a particular material / machine.
Apply Changes
Tool Tree
New Tool
Copy Tool
- Copied from the same tool, different material.
- Tool with identical geometry, any material.
- Created with default values.
Delete Tool
New Tool Group
Export Tools
Import Tools
A tool database file can be imported into the currently open tool database. You will have 3 options,
- Import: This will simply import the given tools under the selected group (or as a top-level tool / group).
- Merge: This will attempt to merge the incoming tool group hierarchy with the current one (without any regards for selection)
- Overwrite: When it's faced with two similarly nested tools that have the same tool geometry, the cutting data of the incoming tool will overwrite the current tool's cutting data for the active machine / material.
- Without overwriting: A new machine / material will be created to contain the cutting data of the incoming tools.
Tool Definition
Tool Type
![V-Bit](https://cdn.sanity.io/images/i7cqi3ri/production/33b4a5ccf34554b583314b816a3610bd3989aa47-56x130.png)
![Engraving](https://cdn.sanity.io/images/i7cqi3ri/production/15397560fd70318e0009420315214851c746bc2b-44x138.png)
![Tapered Ball Nose](https://cdn.sanity.io/images/i7cqi3ri/production/32b8731e3584f4ab4d298abb67c12afd6328ebbd-46x138.png)
![Ball Nose](https://cdn.sanity.io/images/i7cqi3ri/production/be1e537e9bbaa517562903045ab090e0909c4932-36x132.png)
![End Mill](https://cdn.sanity.io/images/i7cqi3ri/production/dee0c5088edab8deb0829920ffd86c69c7dca7b8-33x134.png)
![Radiused End Mill](https://cdn.sanity.io/images/i7cqi3ri/production/e6c95082e6a915cc70e60f8104413f91b0bef450-43x134.png)
![Form Cutters](https://cdn.sanity.io/images/i7cqi3ri/production/1ebde342ab0a2aa63626d41d08d89a1d964d0d05-103x124.png)
![Diamond Drag](https://cdn.sanity.io/images/i7cqi3ri/production/890dfd90c139cfbb615c180aebeb65876ed52fc0-35x129.png)
![Drills](https://cdn.sanity.io/images/i7cqi3ri/production/6543304aa8ef3ecf3943c05693f95da6ad10d5cd-38x138.png)
Notes
Diameter
Number of Flutes
Cutting Data
Creation / Copying
- Create with some default values which you can then change for your purposes.
- Copy from the same tool from a different material: This could be a sensible starting point if the materials have similar / close hardness.
- Copy from a different (identical) tool from the same (or different material)
Pass Depth
Stepover
Final Pass Stepover
Clearance Pass Stepover
Spindle Speed
Feed Rate
Plunge Rate
Material / Machine
Chip Load
Maximum Burn Rate
Tool Number
Per Machine
Material / Machine Management
Material
Machine
Online Tool Database
Download
Download the tool database stored on your portal account to replace your existing local tool database. This can be used for when we know there is a more up-to-date version online.
Upload
Using Form Cutters
![Round-over](https://cdn.sanity.io/images/i7cqi3ri/production/8f1d952560290443847c7ad5cfee90fb5404abef-141x208.png)
![Ogee](https://cdn.sanity.io/images/i7cqi3ri/production/aa15bd83d5af142c34406977c97cc92f33eb85bf-168x208.png)
![Profile Cutting Strategy with Form cutter](https://cdn.sanity.io/images/i7cqi3ri/production/bb2b123159a3940d0f751980ed4cdb95a9d99511-381x208.png)
Custom Form Cutters
Geometry
![](https://cdn.sanity.io/images/i7cqi3ri/production/79b07eb4c9392bd640f547586d8e9084a991dc02-228x200.png)
