Creating a Rotary Job
XY Origin
  • In a job with horizontal orientation (Along X Axis), the X offset will correspond to the length of the cylinder, and the Y offset will be a point along its circumference.
  • In a job with vertical orientation (Along Y Axis), it's the opposite. The Y offset will correspond to the length of the cylinder, and the X offset will be a point along its circumference.
Orientation
Z Origin
Tip:
Vector Layout
Choosing stock material
If the design was created without those considerations in mind, the blank size can always be adjusted in the Job Setupform.
