2D View Controls
See also the Rulers, Guides and Snap Grid section.
![]() | Pan | Click and hold the Left mouse button and drag the mouse about to Pan - Esc to cancel mode Shortcut: Click and drag the Middle mouse button or if using a 2 button mouse, Hold Ctrl + drag with Right Mouse button. | |
![]() | Zoom Interactive | Mouse with Middle Wheel - Scroll wheel in / out Mouse without Middle Wheel - Hold Shift + Push / Pull with Right Mouse button. | |
![]() | Zoom Box | Click top left corner, hold mouse down and drag to bottom right corner and release. Clicking the left mouse button will zoom in, Shift + click will zoom out. | |
![]() | Zoom Extents | Zooms to show material limits in the 2D window | |
![]() | Zoom Selected | With objects selected Zooms to the bounding box of the selection |
Sheets
When there are multiple sheets in the job then the outline of the sheets is shown in the 2D view.
![](https://cdn.sanity.io/images/i7cqi3ri/11/cbd01cbf084734ecdb258c09743bc5dff3a0a02a-1323x757.png)
When vectors lie outside of the bounds of a sheet, then the bounds in the 2D view are updated to indicate this.
![](https://cdn.sanity.io/images/i7cqi3ri/11/9dfae84983a6a0058677878622e4af3c7465a866-1567x902.png)
A sheet can be activated by using the Sheet Management Tab or by double clicking on the sheet in the 2D view.
