Keyboard Shortcuts
Quick Keys
Various values can be typed in while dragging out shapes. In most cases, the left mouse button must be pressed in order to input a value (i.e.dragging to create a circle, dragging a vector to move it, or dragging one of the rotating/scaling points around a vector to rotate/scale it).
The exception to this is the polyline tool and the arc tool. Once the first point is entered the Quick Keys can be used without having to depress the left mouse key. Entering values defines the next end-point.
Space
Pressing Space re-opens the last vector creation form you used. This is very useful when using other forms in between each shape / text / dimension you create
General Shortcut Keys
Keys
Ctrl +A
Select All vectors
Esc
Deselect all vectors
Select Right to Left
Selects all vectors inside and touching selection rectangle
Select Left to Right
Only selects vectors fully inside selection rectangle
N
Toggles between Selection and Node Editing modes
Esc
Switches to Selection Mode (exits Node editing or Transform mode)
T
Opens the Scale form for Transforming the vectors.
M
Opens the Move form
R
Opens the Rotate form
J
Opens the Join Vectors form
9
Rotates selected object 45° counterclockwise
0
Rotates selected object 45° clockwise
Esc
Exits vector drawing and editing tools and closes the data entry form
Right mouse click
Space-bar
Re-opens the last vector creation form you used. This is very useful when using other forms in between each shape / text / dimension you create.
Z
Zoom - click top left and bottom right corners to zoom
Esc
Exits zoom mode returning to Selection mode
Ctrl + F
Zoom to fit Job
F
Zoom to fit Material
F6
F1
Opens the Help File
F2
Opens the 2D Drawing window
F3
Opens the 3D Preview window
F4
Opens the Snap Settings form
F5
Refreshes the 2D window
F6
Scales 2D view to fit material
F9
Center selected object in view
F10
Opens the Alignment Tools form
Right mouse click
Opens context sensitive menus
Ctrl + Z
Edit Undo
Ctrl + Y
Edit Redo
Ctrl + C
Copy the selected vectors
Ctrl + V
Paste the selected vectors
Ctrl and Drag
Pastes a copy of the selected vectors each time the left mouse button is released.
Ctrl + X
Cut the selected vectors
Alt and Drag
Moves the object either horizontally or vertically aligned with its original position
Ctrl + Alt and Drag
Creates a copy of the original object horizontally or vertically aligned to its original position
Ctrl + N
Create New file
Ctrl + O
Open an Existing file
Ctrl + S
Save file
Ctrl + I
Import file
Page Up
Vertically tiles the 2D View and the 3D View window so you can see them both simultaneously. Currently Selected window is on the left - typically best to select the 2D View first when doing this.
Page Down
Horizontally tiles the 2D View and the 3D View window so you can see them both simultaneously. Currently Selected window is at the top - typically best to select the 2D View first when doing this.
Quick Keys
Ctrl + M
Opens Measure tool form
Tab Navigation
Keys
F11
Toggle Drawing Tab on
F12
Toggle Toolpath Tab on
Ctrl + L
Opens the Layers Tab
Ctrl + D
Opens the Drawing Tab
F8
Toggles between the Drawing and Modeling Tab
Double Sided Job Setup
Keys
1
Toggle Top Side on
2
Toggle Bottom Side on
Toggle Multi-Sided View on
Mirror
Keys
H
Mirror Horizontally
Ctrl + H
Create Mirror Copy Horizontally
Shift + H
Mirror Horizontally, around center of material
Ctrl + Shift + H
Create Mirror Copy Horizontally, around center of material
V
Mirror Vertically
Shift + V
Mirror Vertically, around center of material
Ctrl + Shift + V
Create Mirror Copy Vertically, around center of material
Alignment
Keys
F9
Moves selected object to the center of the material
F10
Groups
Keys
G
Group the selected objects
U
Ungroup the selected objects to their original layers, sub-groups remain grouped.
Ctrl + U
Ungroup the selected objects to the group's layer, sub-groups remain grouped.
Shift + U
'Deep' ungroup the selected objects to their original layers. Sub-groups are also ungrouped.
Ctrl + Shift + U
'Deep' ungroup the selected objects to the group's layer. Sub-groups are also ungrouped.
Arrow Keys
Nudge selected vectors using the Arrow keys.
Keys
Hold Ctrl
Reduce the nudge distance
Hold Shift
Increase the nudge distance
Hold Ctrl + Shift
Nudge by the Fixed Nudge Distance which is specified in the Snap Settings (F4)
Node Editing
Available while in the node editing mode.
Drag Node when using Quick Keys.
Keys
I
Insert a Point
D
Delete Point / Span
S
Smooth / Unsmooth Point
C
Cut Vector opens the vector
B
Convert span to Bezier
A
Convert span to Arc
L
Convert span to Line
P
Makes the selected node the Start Point for machining
X
  • Displays a single node's X and Y location properties
  • Modifie la position des coordonnées X des nœuds sélectionnés pour qu'elle corresponde à la position du premier (lorsque plusieurs nœuds sont sélectionnés)
Y
Modifies the position of the Y coordinates of the selected nodes to match the position of the first one (when more than one node is selected)
H
Enter horizontal mirror mode (press again to exit)
V
Enter vertical mirror mode (press again to exit)
K
Toggle Keep Bezier Tangency mode, which will fix the start and end directions of Bezier curves when they are being dragged directly
J
Join two selected open vectors (at two end nodes if also selected)
Right mouse click
Quick Keys
Value Enter
Moves node from original position by that amount in direction of cursor.
Equivalent to:Value L
Value , Value Enter
Move the node by that amount relative to its current position.
Equivalent to: Value D Value W
Value X Value Y
Moves node to the absolute position X and Y
Moving Objects
Drag Object when using Quick Keys.
Quick Keys
Value Enter
Moves object the Value from original position in direction of cursor.
Equivalent to: Value L.
Value , Value Enter
Moves object relative to its position by X and Y.
Equivalent to: Value D Value W.
Value X Value Y
Moves object to the absolute position X and Y
Rotating Objects
Drag rotation handle when using Quick Keys.
Quick Keys
Value Enter
Rotate the selection by Value degrees counterclockwise.
Scaling Objects
Drag scaling handle when using Quick Keys.
Quick Keys
Value Enter
Default when dragging edge scale nodes only.
Set the width or height of the object to 'Value' (depending on which handle is being dragged).
Value , Value Enter
Default when dragging corner scale nodes only.
Set the width and height of the object to the given values.
Value S
Scale the object by a factor.
Polyline Tool
Quick Keys
Value Enter
Places next point Value away from the last point in the direction of cursor.
Value , Value Enter
Place the next point offset by that amount relative to the last point's position:
Value X Value Y
Places the next point at position X and Y
Value A Value L
Creates a line with an angle of A° and a length L
Keys
Backspace
Undo last span
Space
Finish current polyline and start a new one.
Draw Circle
Quick Keys can be used while creating (left mouse button depressed)
Quick Keys
Value Enter
Create a circle with the given radius.
Equivalent to: Value R.
Value D
Create a circle of Diameter D
Draw Ellipse
Quick Keys
Value Enter
Create an Ellipse with the given diameter.
Value , Value Enter
Create an ellipse with width and height.
Equivalent to: Value W Value H.
Value X
Create an ellipse with width X and use the current height
Value Y
Create an ellipse with height Y and use the current width
Draw Rectangle
Quick Keys
Value Enter
Create a sqaure with the given side length.
Value , Value Enter
Create a rectangle with given width and height.
Value X
Create a rectangle with width X and use the current height
Value Y
Create a rectangle with height Y and use the current width
Value R Value X
Create a rectangle with a radius R and width X, using current height
Value R Value Y
Create a rectangle with a radius R and height Y, using current width
Value W Value H
Create a rectangle with width W and height H
Value , Value Enter
Create a rectangle with width and height
Draw Polygon
Quick Keys
Value Enter
Create a polygon inscribed on circle with the given radius.
Equivalent to : Value R.
Value D
Creates a Polygon with diameter D
Value S Value R
Create a polygon with number of sides S and radius R
Value S Value D
Create a polygon with number of sides S and diameter D
Draw Star
Quick Keys
Value Enter
Create a star with the given radius.
Value D
Create a star with diameter D
Value P Value R
Create a star with number of points P and radius R
Value P Value D
Create a star with number of points P and diameter D
Value P Value I Value R
Create a star with number of points P , Internal Radius % I and radius R
Value P Value I Value D
Create a star with number of points P , Internal Radius % I and diameter D
