Modelling 3D spiral features
![](https://cdn.sanity.io/images/i7cqi3ri/11/9343b6952d9b4ba6604461435d18b0362575bb6e-745x1219.png)
The workflow for creating spiral toolpaths has been presented in the Simple rotary modelling using 2D toolpaths chapter. The basic idea involved creating a line at a proper angle to the rotation axis, that exceeded the 2D boundaries. When 2D toolpath is created based on such a line, it will be wrapped around material cylinder, creating a spiral.
To start, select Draw Line/Polyline tool and draw a horizontal line at the bottom of the job from left to right. If it is desired for the spiral pattern to only fill part of the cylinder length, this horizontal line should be drawn only in th desired location. While the drawing tool is still active, type 90 into Angle box and type y * 4 into Length box and pressing =. We used y * 4 formula so the strip will wrap 4 times. Then press Add button to add a vertical segment.
The line that we just created will form a bottom of the strip. Now copy this line and place line so its bottom left end coincides with top left corner of the 2D job. This line will form a top of the strip. Then make another copy and place it in the middle. This middle line will be used later to position our design within strip. All three lines have been shown below.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/0e11937719dc887ca61174a076091d5b90a54fbb-323x1085.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/d8e4d60a809831749ca7fb4379f66a2864cd31d0-408x943.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/cf3f11b4752510d43e5f1bae10fb4db7a003d9ce-835x423.png)
The easiest way to achieve that, is to create a textured component. To do that, select the design in the component tree and activate the Create Texture Area tool. This example used the default settings of the tool. The tool will create a new component that will fill the whole 2D job boundaries. The component itself will be filled with the design in tiled manner. Now use the Set Size tool to resize textured component to match the strip size.
Now the component have to be rotated and moved to fit between the lines you have drawn at the beginning. This process can be made easier by utilizing Copy Along Vectors tool. To proceed, activate the tool and select the textured component first, then select the middle line in the strip while holding Shift. Make sure that Align objects to curve option is selected and use Number of copies option. Since our strip has already have a correct size, we only need one copy. However the tool would place the middle of our component at the beginning of the line only. If you enter 3 as the number of copies, then the tool will place two copies of component at each end and in the middle. Afterwards the copies at the ends can be simply deleted. The picture below shows the strip in the 3D view after being correctly positioned.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/4764e0073d8808a72074fbb0d2617628e7686a90-764x927.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/7bf4e6030017473cab5dca937295dd9c9cf5277e-784x947.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/b42d3c2c3575229b40b704f4908f7e2d6a8e7293-198x245.png)
Note:
The last step is to make column endings. For that purpose the third level was created, with Combine Mode set to Merge. This way the spiral pattern will be 'hidden' at the ends. A circular 3D tab clipart was placed at each end, and stretch vertically to match the job boundaries.
Modelling twisted shapes
![](https://cdn.sanity.io/images/i7cqi3ri/11/fdafd5fa9f491f5dcd5476f53c9c3460964301e4-739x704.png)
This section will show how to create twisted shapes, using a combination of level-wrapping and Vector Unwrapper tool.
In this example a new rotary job was created, with a diameter of 6 inches and length of 20 inches, rotating around X axis. To start, we need a cross-section vector. In this example a 5-armed star was used. To create a star, we can use Draw Star tool. This example used Outer Radius of 3 inches, to match the radius of the material.
The next step is to unwrap the cross section. In the case of the star however, the center is not the same as center of star's bounding box. To find the real center, one can draw a line from two of the star corners. Then open Vector Unwrapper and select the star. Then drag rotation center and snap it to the intersection of the lines, as can be seen below.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/faecd701dfa28689623cebeed6d270b956e3be2c-607x578.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/0e5ddd82fcc5a98bebd92e4c37524184369823d3-462x732.png)
Once the star is unwrapped, we need to create rails, that will make spiral when wrapped. To do that, select Draw Line/Polyline tool and draw a horizontal line at the bottom of the job from left to right. While the drawing tool is still active, type 90 into Angle box and type y * 2 into Length box and pressing =. We used y * 2 formula so the star will make 2 revolutions Then press button to add a vertical segment. Finally, start a new line that connects the horizontal and vertical lines, forming a triangle. Once this line is created, our horizontal and vertical lines can be removed.
To overcome that, select both rails, open Draw Rectangle tool and press . This will create a bounding box containing the rails. Now, write done the size of the box and save current project. Then create a new single-sided project with the slightly bigger than the bounding box. Use the Import Vectors option from the main menu and select the previously saved file. Now select the rails and press F9 to center them.
Now use Two Rail Sweep tool. When component is ready, save the file.
Now re-open the original rotary project. Use Import Component and select the single-sided project created in the step above. Move the component to the desired location. Then, create a new level, move the component there and enable wrapping.
![](https://cdn.sanity.io/images/i7cqi3ri/11/2d2ab00af9aee9aa0bf559919e6142a55e008513-1056x1198.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/600195e555b83823298bcc61164810dfaec2ff89-1439x595.png)
One can simply treat the side cross section as rails and use the Two Rail Sweep tool, placing the half cross sections at appropriate locations. This way half of the leg can be modelled very quickly, with the result that can be seen below (using flat 3D view).
![](https://cdn.sanity.io/images/i7cqi3ri/11/e3e6bf719d2a24e9a3d91b7fb9ec99b2056d3419-1366x282.png)
In order to use the created model in a rotary project, we need to export and then import it back. Although it is possible to do this with two sessions of Aspire, it can also be done within a single session with rotary project. To export the leg model, make sure no other components are visible (including the automatically added zero plane) and open the Export Model tool while holding down Shift. Pressing Shift allows to open the export tool in single-sided, rather than rotary mode.
Since half of the leg was modelled, Close with inverted front option can be used. The resulting STL mesh can be seen below.
![](https://cdn.sanity.io/images/i7cqi3ri/11/9c34ed59597134a4ec0e5d52843fafd28b9b12d8-1145x852.png)
Once component is exported, it can be re-imported as Full 3D model. The model will have a seam, in the place were two halfs were merged. This can be removed using smoothing function of the Sculpting tool.
