3D Design and Management
The 3D View
The Composite Model
![test](https://cdn.sanity.io/images/i7cqi3ri/11/b6b33d77e5c1e1f11d0477c15e7dab3233eb12cb-333x335.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/b7e44fd29f7132717f66a5e87483c6cd05523a55-333x335.png)
Dynamic Properties
Combine Modes
![test](https://cdn.sanity.io/images/i7cqi3ri/11/796c078bfa724bed7682fcbe423f8c7d07785305-177x175.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/cd683a1a4d502a12d8a1042b8c9334fb0544e789-255x209.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/b0caf9e7ac3aa6be59cd4a89d467d7e5256b1f07-254x206.png)
Note:
Add
![test](https://cdn.sanity.io/images/i7cqi3ri/11/b7053d918223babe45ea89892ba20f9dc604fba7-255x206.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/ebbee40c844da01b37fb57b61f9830e10a7e7895-355x206.png)
Subtract
![test](https://cdn.sanity.io/images/i7cqi3ri/11/df013f5c682c666699c62de39cf787f9f546892e-255x214.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/a623cd1ec3b9df07eb7c99ba64c920d618e00a5f-351x214.png)
Merge
![test](https://cdn.sanity.io/images/i7cqi3ri/11/81d85cd8e4120cf1ae449a3ec62fc89c018de4f4-255x208.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/6aea70b3c115fbbc23cad4650c7778e63fdc241e-383x208.png)
Low
![test](https://cdn.sanity.io/images/i7cqi3ri/11/ecf169e889887b67cc67485459b5966c76e0e286-255x206.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/191315e879a5752f12f703abe1553f6217311000-306x206.png)
Level Mirror Modes
- Left to Right
- Right to Left
- Top to Bottom
- Bottom to Top
![](https://cdn.sanity.io/images/i7cqi3ri/11/dd792d2eb7668b9f3f7fcaafd06d4c446e6bff7d-106x150.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/8e35c22bf28c4aed5564e9fe18e230512d881c40-150x150.png)
- Top Left Quadrant
- Top Right Quadrant
- Bottom Left Quadrant
- Bottom Right Quadrant
Multi Sided View
![](https://cdn.sanity.io/images/i7cqi3ri/11/47e182c234fba773ec91bdbc4723498beea914fa-29x25.png)
