Rotary Machining and Wrapping
Aspire can 'wrap' flat toolpaths around a cylinder to provide output to CNC machines which are configured with a rotary axis / indexer. The image below shows a flat toolpath wrapped around part of a cylinder.
Aspire can also visualize a wrapped model within the program by drawing the shaded composite model wrapped.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/b4371d1e37ab106c06777c6d7696f306eb3543e6-200x175.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/20cc7f644ff150d63e2820d27a16be3e76a4672e-365x400.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/d017e97ac1202e1120c893b8f14405c47f6ace95-319x400.png)
Aspire also has the ability to draw the toolpath simulation wrapped. Although this is very useful for getting a feel for how the finished product will look, it is important to realize that the wrapped simulation may not be a 100% accurate representation of how the finished product will look. An example of potential difference would be if you drilled holes in your rotary job. In the actual work piece these will obviously just be round holes, in the wrapped simulation these may appear as distorted ovals due to the 'stretching' process which takes place when we wrap the flat simulation model for display.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/3791848de282ddee158985b10521d7e384185d19-282x581.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/7b5de66b2e7d4a3e9e9fd669b28d15429f4a786e-372x529.png)
