Chamfer Toolpath
![](https://cdn.sanity.io/images/i7cqi3ri/11/065330d410e0d73e9ca732154cd98716175fb0bc-277x685.png)
The Chamfer Toolpath uses the selected vectors and tool to create an angled feature
![](https://cdn.sanity.io/images/i7cqi3ri/11/487dd2b769c88d586e9ca77899d3770b8ab863d7-636x381.png)
The Chamfer Toolpath has two distinct ways of operating depending on the tool used:
- If the selected tool is an angled tool, then the angle of the tool determines the angle of the chamfer
- If the selected tool is a round nosed tool, then the angle of the chamfer must be specified manually, and will be approximated by a series of fine cuts.
Cutting Depths
The Start Depth (D) specifies the depth at which the top of the chamfer should start.
To create the toolpath you must first draw and then select the vectors you wish to create the chamfer on.
Tool
Chamfer Dimensions
The chamfer dimensions control the shape of the created chamfer.
Angle (A)
The angle determines the slope of the chamfer. It is measured from vertical.
When a V-Bit tool is selected for the toolpath then the angle is fixed to half of the angle of the tool.
For a round nosed tool then the angle may be specified.
Width (W)
The width determines the horizontal size of the chamfer. If the angle is set then changing the width will change the cut depth proportionally.
Cut Depth (C)
The Cut depth is the height of the chamfer. If angle is set then changing the cut depth will change the width proportionally.
Max Cut Depth
To achieve the desired height of the chamfer, as specified by the cut depth field, cutting deeper might be required. This will be true in the case of a round-nosed tool.
![](https://cdn.sanity.io/images/i7cqi3ri/11/d70cd45b9b31533d2f749136b94914bc249a5284-386x332.png)
The Max Cut Depth field is read only and shows the full length of the cut so you can accurately see how deep the tool cuts.
Overcut
When using a V-Bit tool for chamfering it can be desirable to use the edge of tool, and keep the point of the tool off the part. Small movements in the machine and the material can mean that the point of the leaves an unsightly witness mark. The overcut control allows you to specify a value that will be used to offset the centre of the tool, and use the side of the tool for machining.
The length of the side of the tool is unknown and so when specifying an overcut distance you should always ensure that the cutting edge of the tool is long enough to accomodate the overcut distance.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/d4b82204600109ed8c4df494ccdd02c396314408-890x586.png)
Chamfer Type
The Chamfer Type option controls whether or not a chamfer occurs inside or outside a vector and the direction of the chamfer slope :
- An inner chamfer will be inside the selected vector.
- An outside chamfer will be outside the selected vector.
The direction of the slope tells us whether our chamfer is upward or downward relative to the selected vector or whether it is downward relative to the selected vector.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/2551bbacb1d0783fdbb4a932941fc18829eca672-1041x890.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/42c70e0f8d981fe8ec3d7c14190441763c76e15e-1041x890.png)
Both options can be used together to generate different chamfer styles.
2D Preview
When using the Chamfer toolpath the 2D View will provide immeditate feedback on what the resulting chamfer will look like. Small lines will extend outwards from the selected vector to show where the slope of the chamfer will lie. The arrows on these line indicate the direction of slope. The arrows always point down in the direction of the downwards slope.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/6dfcc1871d584abf7b4a99e66a1163031ddab265-1041x890.png)
Use Vector Selection Order
If this option is checked, ✓ the vectors will be machined in the order you selected them. If the option is not checked the program will optimize the order to reduce machining time.
