Create Shape
![](https://cdn.sanity.io/images/i7cqi3ri/11/05faa26bcf495613532d5fe80afa28563c4c65bd-243x695.png)
The Create Shape tool allows the user to create Components based on one or more closed vectors. The vectors can be selected either before the icon is clicked or after the form is open. The user works through the form specifying the profile and strength of the shape and modifying options to govern its height. There is also an option to Tilt the shape on an angle. Once any of the parameters have been defined the shape can be previewed by hitting .
This shape can be easily changed by altering the parameters in the form and hitting the button to update the preview. Once you are happy with the shape created then you have two choices, to (which will save your current component and start a new one) or the form.
Changing values with the sliders on the form will immediately update the 3D view when you release the slider. If you make changes to the edit fields such as Angle or Base height, pressing the 'Space' bar on your keyboard after you have finished entering your value will apply the changes and update the 3D preview or you can hit the button again.
If you select another vector, then the current shape will be discarded, so remember to hit if you want to keep a copy of it.
Shape Profile
There are six different shape types:
Curved
![](https://cdn.sanity.io/images/i7cqi3ri/11/6959b2c57acf65ce6fd71e5b1b1133694cae27d3-70x30.png)
Angle
![](https://cdn.sanity.io/images/i7cqi3ri/11/889f0f5627de085d53597ef2466591cf21fcbd95-70x30.png)
The Angle setting will define the angle of the edge of the rounded or angled profile shape - the higher the angle, the steeper the shape. Angular shapes can have a maximum angle of 89°. The slider bar to the right can also be used to change this as well as typing a specific angle into the form.
Concave
![](https://cdn.sanity.io/images/i7cqi3ri/11/07b34b397e12cc5c5ee5308e97dff0f530d2751a-69x31.png)
S-Shaped
![](https://cdn.sanity.io/images/i7cqi3ri/11/7df62d014606e23ce15b78464b262e8d709b2c3f-70x34.png)
Flat
![](https://cdn.sanity.io/images/i7cqi3ri/11/03be1479812ad759336f36b2f6401c74562b9008-70x30.png)
Custom
The custom shape profile uses a vector to define the profile rather than using one of the standard profiles.
To use the custom profile option a selection of closed vectors, plus an additional open vector representing the profile, must be selected.
When using a custom profile, the form the final shape will take comes from considering the shape above the line joining the end points. For this reason the profile vector should usually have a leg.
![test](https://cdn.sanity.io/images/i7cqi3ri/11/d556f4fdcbb1c4b58ec83afbb4eae11f582177a3-244x219.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/2eb89bc20761b5e9e5176194955cb4569096d46a-1046x869.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/c3bf0740817d43e7c60aadafe0b32a07390e16fd-511x197.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/5b4fd46f7346ffea43dfbc872d8fb83e32564c67-1047x858.png)
Final Height
No Limit
Checking ✓ this option lets the combination of the size and shape of the vector and the specified profile values govern the final height of the shape.
Limit to Height
Checking ✓ this option limits the height of the shape by flattening it off at the value entered in the Height area of the form which becomes active once this option is selected.
Scale to Exact Height
Checking ✓ this option limits the height of the shape by scaling the shape up or down while retaining its general specified profile. It is scaled to the height entered in the Height area of the form which becomes available once this option is selected. The slider can also be used to change the final height.
The Base Height value is not included or controlled by the Final Height setting and if specified will be added to this value to give the total height of the component being created.
Blend To Inner Vectors
This option applies the selected profile across the selected vectors. It blends to the profile from the outside of the vectors to the inner vectors
![test](https://cdn.sanity.io/images/i7cqi3ri/11/218b8c8bb0bb75e2ce6cd8875f49770ec8c1ac15-281x273.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/82093af222da324812a37f6f224fda9b9868cd27-497x461.png)
Sweep
The sweep option takes the profile chosen and sweeps this profile around the selected vector, blending the profile inwards, but not distorting the original profile. This is particularly useful when used in conjunction with the custom profile.
Tilt
When this option is checked ✓ the user can set a direction and angle to tilt the shape up at an angle in Z. The first part of this operation (once the option is checked ✓) is to press the button - then click two points in the 2D view.
The second click specifies the point that will be tilted upwards by the specified angle (the point that will be raised up).
The default angle (10°) can be edited by clicking the arrow next to the value and using the slider or by typing in a specific value and hitting the Space Bar on the keyboard to apply the angle.
Common Modeling Options
![](https://cdn.sanity.io/images/i7cqi3ri/11/3ccc096a2836888fc7707fb98da65846f53690d6-221x79.png)
Reset
Apply
Start New Component
Close
