Text On A Curve
Text Size
Maintain text Size
Scale text to fill curve
Text Spacing
Text Position
Above Curve
On Curve
Below Curve
Text on other side
Offset Distance
Text Alignment
test
Align to Curve
test
Keep Vertical
Position on the curve
The text's position on the curve can be adjusted interactively, by dragging the anchor point handle in 2D View.
Detaching from the curve
The text object that was wrapped on a curve can be detached from it.
To detach text right-click on the selected text object and select "Remove Text From The Curve" option.
