Toolpaths
Show Toolpaths Tab
Can be checked ✓ on or off to pin the Toolpath Tab open or unpin and hide it.
Recalculate All Toolpaths
Recalculate all toolpaths in the project.
Toolpath Drawing ►
Opens the Toolpath Drawing submenu.
Preview Simulation Quality ►
This controls the resolution (number of points) in the Toolpath Preview simulation model governing the amount of detail that the model will display when you Preview and toolpath. The higher the quality, the slower the speed of simulation will become. Guidelines are given on how much slower you should expect it to be but these will depend upon the performance of the PC and relative size of the tool being used to your job (the larger the tool, the slower the performance).
  • Standard is the fastest mode and recommended for low performance PC's.
  • High (2 x Slower) displays better quality images and is for general use.
  • Very High (4 x Slower) displays good quality images, but will run a little slower.
  • Extremely High (8 x Slower) gives good quality images but will run slower on old PC's.
  • Maximum (25 x Slower) gives the best quality image, but could take a lot longer on any PC.
Templates ►
Opens the Toolpath Templates submenu
Merge Visible Toolpaths
Opens the Create Merged Toolpath Form to merge different toolpaths that use the same tool into one optimised toolpath.
Create Job Sheet
Creates a job setup sheet which gives an overview of all of the toolpaths in the job. This opens a File Save As dialog prompting for a place to save the created sheet. The created job setup sheet is a single page of HTML, suitable for viewing in a web browser of your choice, or for printing. This can also be customized with the Job Setup Sheet Editor in the Gadgets Menu.
Materials...
Opens the Material Management dialog of the Tool Database
Tool Database...
Opens the Tool Database Dialog.
Toolpath Drawing sub-menu
Draw 2D Previews
Can be checked ✓ on or off to display the toolpath previews in the 2D View.
Make 2D Previews Solid
Can be checked ✓ on or off to switch from the wireframe view to a solid view.
Auto Open 3D View
Selects whether the 3D view and Preview Toolpaths Form are automatically shown after toolpaths are created.
Draw rapid moves
Toggles the visibility of red rapid-speed move lines on the 3D view when toolpaths are visible.
Draw plunge moves
Toggles the visibility of cyan plunge-speed move lines on the 3D view when toolpaths are visible.
Draw retract moves
Toggles the visibility of green retract-speed move lines on the 3D view when toolpaths are visible.
Draw join moves
Toggles the visibility of purple join move lines on the 3D view when toolpaths are visible. A join move is a purely 2D move between toolpath contours, these are typically seen in Offset pattern Pocket Toolpaths.
Templates sub-menu
Save Selected Toolpath as Template
Saves the toolpath that is currently selected as a template for use in another project.
Save All Visible Toolpaths as Template
Saves all of the currently visible toolpaths as a single template for re-use in another project.
Load Template
Loads a previously stored template containing all the settings for one or more toolpath strategies.
