2D View Controls
See also the Rulers, Guides and Snap Grid section.
Pan
Click and hold the Left mouse button and drag the mouse about to Pan - Esc to cancel mode
Shortcut: Click and drag the Middle mouse button or if using a 2 button mouse, Hold Ctrl + drag with Right Mouse button.
Zoom Interactive
Mouse with Middle Wheel - Scroll wheel in / out
Mouse without Middle Wheel - Hold Shift + Push / Pull with Right Mouse button.
Zoom Box
Click top left corner, hold mouse down and drag to bottom right corner and release. Clicking the left mouse button will zoom in, Shift + click will zoom out.
Zoom Extents
Zooms to show material limits in the 2D window
Zoom Selected
With objects selected
Zooms to the bounding box of the selection
Sheets
When there are multiple sheets in the job then the outline of the sheets is shown in the 2D view.
When vectors lie outside of the bounds of a sheet, then the bounds in the 2D view are updated to indicate this.
A sheet can be activated by using the Sheet Management Tab or by double clicking on the sheet in the 2D view.
