Tool Database - Name Format
Format
The template contains variables of the format {Variable Name} which will be substituted by their real value for the tool.
  • For example, {Tool Type} will be End Mill for an End Mill tool and Ball Nose for a Ball Nose tool.
  • We can optionally format those the values in certain ways using modifiers {Variable Name|Modifier}. In the above example, {Tool Type|U} would result in END MILL or BALL NOSE.
  • We have materials MDF and Oak and a tool with the name template {Tool Type} {Diameter} {Material Name}. The tool is an 0.5 inch End Mill.
  • When the MDF material is active, the name of the tool becomes End Mill 0.5 MDF. When it Oak is active, it becomes End Mill 0.5 Oak.
  • When the tool is selected for toolpathing, the name of the tool with the correct material name will be used allowing you to see straight away which variant of the tool you've used.
Set as Default
Any tool which does not have the default name format for its type can be restored using the next to the format field.
Update existing tools
  1. Rename all the tools that had a matching name.
  2. Rename all the tools indiscriminantly.
List of Variables
Here is the complete list of variables that can be used in the format.
In some cases, we may not be able to find a valid value. For example, if we use the {Material Name} when no material is active. In this case, we will simply keep the name of the variable in the tool name. This should not happen if the tool is valid / suitable for toolpath selection.
Variable
Type
Geometry
{Tool Type}
String
{Units}
String
{Units Short}
String
{Diameter}
Float
{Included Angle}
Float
{Side Angle}
Float
{Tip Radius}
Float
{Flat Diameter}
Float
{Num Flutes}
Integer
{Max Power}
Integer
Cutting Parameters
{Length Units}
String
{Length Units Short}
String
{Pass Depth}
Float
{Stepover}
Float
{Final Pass Stepover}
Float
{Clearance Pass Stepover}
Float
{Num Passes}
Integer
{Kerf}
Float
{Line Width}
Float
Feeds & Speeds
{Rate Units}
String
{Move Speed}
Float
{Plunge Rate}
Float
{Spindle Speed}
Integer
{Spindle Direction}
String
{Power}
Float
{Maximum Burn Rate}
Float
{Tool Number}
Integer
Material
{Material Name}
String
Machine
{Machine Name}
String
{Machine Model}
String
{Machine Make}
String
{Machine Controller}
String
List of Modifiers
Variable Type
Modifiers
String
U Uppercase
Example: {Tool Type|U} => END MILL
L Lowercase
Example: {Tool Type|L} => end mill
Float
00.00 Padding / Decimal Points
  • The number of zeros to the left of the dot control the padding.
  • The number of zeros to the right of the dot control the number of decimal points.
  • {Diameter|0.00} => 1.51
  • {Diameter|0.0} => 1.5
  • {Diameter|00.0} => 01.5
F Fraction in inches
Example (for an 1/8 inch diameter):
  • {Diameter} => 0.125
  • {Diameter|F} => 1/8
