Importing Full-3D models
Overview
  1. Setting-up rotary project
  2. Choosing file for import
  3. Orientating the model in material block
  4. Scaling the model
  5. Finishing the import
Setting up a rotary project
To start the importing process, use Import a Component or 3D Model tool from the Modelling tab
test
test
The same model imported without distortion
test
3-axis rotary machining, tool correctly positioned
test
3-axis rotary machining, tool side is touching the stock
Scaling imported model
Finishing import
Importing Flat Models
If the imported model is not aligned with any of the axes, it may be necessary to use Interactive Rotation. The default option - XYZ View - disables interactive rotation. That means that 3D view can be twiddled with a mouse. Selecting other options enables rotation around specified axis.
