Importing Full-3D models
![](https://cdn.sanity.io/images/i7cqi3ri/11/807e48c79c71580793551478a8ce5e92e942d586-2011x950.png)
Overview
- Setting-up rotary project
- Choosing file for import
- Scaling the model
- Finishing the import
Setting up a rotary project
![](https://cdn.sanity.io/images/i7cqi3ri/11/a039b7b2dcba4b5f9659564fc48d2cb5300cce36-1786x843.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/e7ae4271053dd46a15fe89249b617fb26ecb3bfb-1163x638.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/bbd85bb04e5fefdd6618fa321c06127c7601db74-891x555.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/6e1bf61147d5214453ebbdc9348ed7d5423229e5-221x184.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/22ecde75d90fadcccc6d446ef013de04dbb4da6a-1989x802.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/96fdbe801cfeeb1d6fc5cdcc5b75fdf081a71218-221x70.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/9cf5b10a9e7a7cbbb18d37463436ff3e79a866eb-423x520.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/83b913543f75f1bc7d54046c70cff281708f5fc4-423x502.png)
Scaling imported model
![](https://cdn.sanity.io/images/i7cqi3ri/11/b81433cc877bff60124afce2084fd9674a8f4fca-1129x779.png)
Finishing import
![](https://cdn.sanity.io/images/i7cqi3ri/11/cf68dbf5bdbcb839b7e04ec36544b5b87adc4838-1448x1035.png)
Importing Flat Models
![](https://cdn.sanity.io/images/i7cqi3ri/11/4b8bd8f49a566d8246b2efd7bcaea04347e20373-1090x929.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/3cb7a9337f7de46208c2c43f01f6e11942c4a863-221x184.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/29e355784bc5be07035fcd91e80b12381ac1c85b-825x137.png)
