![](https://cdn.sanity.io/images/i7cqi3ri/11/e939dea41b1b5c1377ec3d39fb4b9cb259700c2a-999x842.png)
Creating rotary toolpaths
![test](https://cdn.sanity.io/images/i7cqi3ri/11/f722b9b7001563f47c04f76e0fafc1dd5a86f4ea-775x600.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/6fa6eaa4fbc534545b16cc2af3e0c7e448655ba8-924x673.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/06a50e004ea55a5430bce0f2489588971c289f6b-682x638.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/ee1c4b68f8ea523cd634e4ec971647c7b21dbdd7-973x701.png)
Spiral toolpaths
![test](https://cdn.sanity.io/images/i7cqi3ri/11/6a20507e984762018d901acc1eb553509be1b2a5-267x710.png)
![test](https://cdn.sanity.io/images/i7cqi3ri/11/2c3fecb6cbd725551afe1007587cc46a74722135-341x1269.png)
![](https://cdn.sanity.io/images/i7cqi3ri/11/714de6ab56efb1d56cd11d9292772144f51f6624-1164x996.png)
